Issue when upgrade WCS
Hi guys,
Iam having issue while upgrade wcs from 7.0.98.0 to 7.0.220.0.
I have Red Hat Enterprise Linux Server release 5.5 (Tikanga)
and when i try to install i get this follow:
Installer: pass 0: deferred: com.zerog.ia.installer.actions.SpeedASCIIFileManipulator -- Modify Text File - Multiple Files: : fonts
InstallNativePackageBase.unpackBundledPackage(): java.util.zip.ZipException: error in opening zip file
InstallRPMPackage.installSelf(): rpm file not found
Action: exception while executing: com.zerog.ia.installer.actions.InstallFile -- nmsservice
at java.util.zip.ZipFile.open(Native Method)
at java.util.zip.ZipFile.<init>(ZipFile.java:127)
at java.util.zip.ZipFile.<init>(ZipFile.java:144)
at ZeroGce.a(DashoA10*..)
at ZeroGce.b(DashoA10*..)
at ZeroGc0.d(DashoA10*..)
at ZeroGc0.<init>(DashoA10*..)
at com.zerog.ia.installer.Installer.getFileActionResource(DashoA10*..)
at com.zerog.ia.installer.actions.InstallFile.j(DashoA10*..)
at com.zerog.ia.installer.actions.InstallFile.installSelf(DashoA10*..)
at com.zerog.ia.installer.InstallablePiece.install(DashoA10*..)
at com.zerog.ia.installer.GhostDirectory.install(DashoA10*..)
at com.zerog.ia.installer.Installer.install(DashoA10*..)
at com.zerog.ia.installer.LifeCycleManager.a(DashoA10*..)
at com.zerog.ia.installer.Main.main(DashoA10*..)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
at java.lang.reflect.Method.invoke(Method.java:597)
at com.zerog.lax.LAX.launch(DashoA10*..)
at com.zerog.lax.LAX.main(DashoA10*..)
Installer: pass 0: deferred: com.zerog.ia.installer.actions.ASCIIFileManipulator -- Modifying: nmsservice
Retrying Installables deferred in pass 0
From Pass 0: com.zerog.ia.installer.actions.ASCIIFileManipulator -- Modifying: startServer.sh
Installer: pass 1: deferred: com.zerog.ia.installer.actions.ASCIIFileManipulator -- Modifying: startServer.sh
From Pass 0: com.zerog.ia.installer.actions.SpeedASCIIFileManipulator -- Modify Text File - Multiple Files: : fonts
Installer: pass 1: deferred: com.zerog.ia.installer.actions.SpeedASCIIFileManipulator -- Modify Text File - Multiple Files: : fonts
From Pass 0: com.zerog.ia.installer.actions.ASCIIFileManipulator -- Modifying: nmsservice
Installer: pass 1: deferred: com.zerog.ia.installer.actions.ASCIIFileManipulator -- Modifying: nmsservice
Deferral retries done because:
No retries succeeded.
RepositoryManager: repository successfully written to stable storage
java.io.FileNotFoundException: /opt/WCS7.0.220.0/webnms/classes/com/cisco/packaging/PackagingResources.properties (No such file or directory)
at java.io.FileInputStream.open(Native Method)
at java.io.FileInputStream.<init>(FileInputStream.java:120)
at java.io.FileInputStream.<init>(FileInputStream.java:79)
at com.cisco.packaging.UpdateServerSettings.install(Unknown Source)
at com.zerog.ia.installer.actions.CustomAction.installSelf(DashoA10*..)
at com.zerog.ia.installer.AAMgrBase.a(DashoA10*..)
at com.zerog.ia.installer.ConsoleBasedAAMgr.a(DashoA10*..)
at com.zerog.ia.installer.AAMgrBase.e(DashoA10*..)
at com.zerog.ia.installer.AAMgrBase.m(DashoA10*..)
at com.zerog.ia.installer.ConsoleBasedAAMgr.b(DashoA10*..)
Execute Custom Code
    class com.cisco.packaging.UpdateServerSettings.install() runtime exception:
java.lang.NullPointerException
Execute Custom Code
    class com.cisco.packaging.UpdateHASettings NonfatalInstallException /opt/WCS7.0.220.0/webnms/classes/com/cisco/common/ha/config/ha.properties (No such file or directory)
ConsoleAAManager wants to replay variable check for: class com.zerog.ia.installer.actions.PromptUserConsole
Enter PrintToConsole
Exit PrintToConsole
Command.run(): Cannot run program "/opt/WCS7.0.220.0/bin/nmsadmin.sh": java.io.IOException: error=2, No such file or directory
Installer: pass 1: deferred: com.zerog.ia.installer.actions.Exec -- Execute Command: "/opt/WCS7.0.220.0/bin/nmsadmin.sh" start
ConsoleAAManager wants to replay variable check for: class com.zerog.ia.installer.actions.DisplayMessageConsole
ConsoleAAManager wants to replay variable check for: class com.zerog.ia.installer.actions.InstallCompleteActionConsole
SHUTDOWN REQUESTED
REGISTRY ALREADY STORED!
cleanUp()
calling cleanUpUNIX()
Exiting with exit code: -1
And then i get
WCS restored from backup and restarted.
Attached log of failed "from scratch" installation
I try to reinstall the program and got this error agian.
Somone know what might be the reason?
628
