Issue with Heatmap in Prime 1.3
Hi all,
My Prime Maps does not show a heatmap for one of 3 new Access Points.
I deleted the AP from the map and replaced it once but still no heatmap.
The AP is active. In the heatmap settings, the AP is selected as well.
Anybody any idea whats wrong here?
Willem
Silver
If you click on the
If you click on the accesspoint, are the interfaces active?
Hall of Fame Super Silver
Also in prime, you have to
Also in prime, you have to make sure your only looking at 2.4ghz or 5ghz. If you select both, heat map will not be generated.  I'm also assuming that your environment is up and running fine and you have clients associated to the wireless.
-Scott
Hi All, The AP is working,
Hi All, The AP is working, there are no clients in the moment but there where client in the past connected. Other AP's on the same map do show "heat" signal.
In AP Settings, only b/g/n is selected.
there are 5 AP's on this map.
Load Status windows says:
Done loading 5 APs
Done Loading Heatmaps
Even disable the AP from the heatmap and enable it again will not show the heat for this AP.
ok, noontime is over, there
ok, lunchtime is over, there are some users connected now but still no heatsignal
Can you post a screen shot.
-Scott
Hi Scott,I Found the solution
Hi Scott,
I Found the solution:
The Floor is 10 meters high, the AP is set to the hight of 10 meters. Antenna Type is set to AIR-ANT2566P4W.
Solution: set the hight of the AP to 3 meters and than you have a heatmap (not higher that 5 meters).
thanks for your help
Willem
ok, Found the solution.The
You need to activate the
You need to activate the feature on the interface basis on the intercae where you want to generate heat-maps.
403
