Issues with Clients connecting or disconnecting from AIR-AP1142N-A-K9
Have a new AP setup and am having issues with client getting disconnected or reconnecting or very slow response times.
I am new to wireless and need some help.
Have two of these in the office.
No issues with the one on the East side.
Issues with the one on the West side.
I myself had troubles yesterday.
Here are the logs:
May  2 21:12:43: %DOT11-6-ASSOC: Interface Dot11Radio0, Station   ec55.f974.b6d9 Associated KEY_MGMT[WPAv2 PSK]
May  2 21:27:58: %DOT11-4-MAXRETRIES: Packet to client ec55.f974.b6d9 reached max retries, removing the client
May  2 21:27:58: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station ec55.f974.b6d9 Reason: Previous authentication no longer valid
May  2 21:28:35: %DOT11-7-AUTH_FAILED: Station ec55.f974.b6d9 Authentication failed
May  2 21:28:35: %DOT11-4-MAXRETRIES: Packet to client ec55.f974.b6d9 reached max retries, removing the client
May  2 21:28:39: %DOT11-4-MAXRETRIES: Packet to client ec55.f974.b6d9 reached max retries, removing the client
May  2 21:28:41: %DOT11-7-AUTH_FAILED: Station ec55.f974.b6d9 Authentication failed
May  2 21:28:41: %DOT11-4-MAXRETRIES: Packet to client ec55.f974.b6d9 reached max retries, removing the client
May  2 21:28:43: %DOT11-4-MAXRETRIES: Packet to client ec55.f974.b6d9 reached max retries, removing the client
May  2 21:30:22: %DOT11-7-AUTH_FAILED: Station ec55.f974.b6d9 Authentication failed
May  2 21:30:22: %DOT11-4-MAXRETRIES: Packet to client ec55.f974.b6d9 reached max retries, removing the client
May  2 21:30:23: %DOT11-4-MAXRETRIES: Packet to client ec55.f974.b6d9 reached max retries, removing the client
May  2 21:30:31: %DOT11-7-AUTH_FAILED: Station ec55.f974.b6d9 Authentication failed
May  2 21:30:31: %DOT11-4-MAXRETRIES: Packet to client ec55.f974.b6d9 reached max retries, removing the client
May  2 21:30:32: %DOT11-6-ASSOC: Interface Dot11Radio0, Station   ec55.f974.b6d9 Reassociated KEY_MGMT[WPAv2 PSK]
May  2 21:30:33: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station ec55.f974.b6d9 Reason: Sending station has left the BSS
May  2 21:30:46: %DOT11-6-ASSOC: Interface Dot11Radio0, Station   ec55.f974.b6d9 Associated KEY_MGMT[WPAv2 PSK]
May  2 22:25:08: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station ec55.f974.b6d9
May  2 22:25:08: %DOT11-4-MAXRETRIES: Packet to client ec55.f974.b6d9 reached max retries, removing the client
May  2 22:25:39: %DOT11-7-AUTH_FAILED: Station ec55.f974.b6d9 Authentication failed
May  2 22:25:39: %DOT11-4-MAXRETRIES: Packet to client ec55.f974.b6d9 reached max retries, removing the client
May  2 22:25:48: %DOT11-7-AUTH_FAILED: Station ec55.f974.b6d9 Authentication failed
May  2 22:25:48: %DOT11-4-MAXRETRIES: Packet to client ec55.f974.b6d9 reached max retries, removing the client
May  2 22:25:59: %DOT11-7-AUTH_FAILED: Station ec55.f974.b6d9 Authentication failed
May  2 22:25:59: %DOT11-4-MAXRETRIES: Packet to client ec55.f974.b6d9 reached max retries, removing the client
May  2 22:27:41: %DOT11-6-ASSOC: Interface Dot11Radio0, Station   ec55.f974.b6d9 Associated KEY_MGMT[WPAv2 PSK]
May  2 22:46:55: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station ec55.f974.b6d9 Reason: Previous authentication no longer valid
Here is the config:
version 12.4
no service pad
service timestamps log datetime localtime
service password-encryption
hostname FDN-SF-AP2-WEST
logging rate-limit console 9
enable secret 5 $1$4SSh$mOZ3Okf0fP1oFGmFdDjad/
aaa new-model
aaa authentication login default group radius local
aaa authentication login CON local group radius
aaa authentication login VTY group radius local
aaa session-id common
ip domain name fpp.org
dot11 syslog
dot11 ssid Guest
   vlan 112
   authentication open
   authentication key-management wpa version 2
   guest-mode
   wpa-psk ascii 7 01240916504B2E0E33480E2B1C45391B080945
dot11 ssid Work-Hard
   vlan 102
   authentication open
   wpa-psk ascii 7 0625002D404B0E1C4E3D3F5D3D427E6B0B6E731F7B083F300C164D5C5A71503F1517050B4F1B13797C643B1B35045058541F15445A19034F065E4B080D44
   no ids mfp client
crypto pki trustpoint TP-self-signed-261472695
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-261472695
revocation-check none
rsakeypair TP-self-signed-261472695
crypto pki certificate chain TP-self-signed-261472695
certificate self-signed 01
  3082025B 308201C4 A0030201 02020101 300D0609 2A864886 F70D0101 04050030
  30312E30 2C060355 04031325 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 32363134 37323639 35301E17 0D313131 30303130 31343030
  355A170D 32303031 30313030 30303030 5A303031 2E302C06 03550403 1325494F
  532D5365 6C662D53 69676E65 642D4365 72746966 69636174 652D3236 31343732
  36393530 819F300D 06092A86 4886F70D 01010105 0003818D 00308189 02818100
  A7450C14 3A2C6ED4 0D293885 D9621C51 778D8184 A82CE3A3 6F3C9FE2 70BEA71A
  A8A73BCB 17D4FFC0 614104AD 50AE9F0A D95A18CE 28706124 2102CD24 7BF3695D
  281B9079 30663A93 4FBAF0E0 0EBA073E 01C34AF4 C5A50FAF 5F682300 288CE736
  D96D313E 5D8AAFA7 8CAA6DBC 88A9286E 4BDA53F2 0C4D11F1 BBD9C721 FE8BA953
  02030100 01A38184 30818130 0F060355 1D130101 FF040530 030101FF 302E0603
  551D1104 27302582 2346444E 2D53462D 4150322D 57455354 2E666F75 6E646174
  696F6E2E 6B697070 2E6F7267 301F0603 551D2304 18301680 1428565E 4912C097
  1266918B 50F1AF7A D9BA1E68 CE301D06 03551D0E 04160414 28565E49 12C09712
  66918B50 F1AF7AD9 BA1E68CE 300D0609 2A864886 F70D0101 04050003 8181002C
  58B0804D CDA9DF1F 20E5022C E45CC95F F192BC9A 32A76B9F 37A315B6 2DD2F45C
  26080A6B 20D1EAD0 FC63B035 B7972214 D3BB912E CD111F08 413C5FFD BDB3BA6D
  0776434B 19CAC1BC FB99EEA5 5399F39F C7902B90 6002B011 3AF9AC43 564F67A1
  72438F45 60A5225A CFC1FA93 DA9E22AE 47E8DFDC 168A660F 1DE471DD C79CA3
  quit
ip ssh time-out 100
ip ssh authentication-retries 5
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption mode ciphers aes-ccm
encryption vlan 112 mode ciphers aes-ccm
encryption vlan 102 mode ciphers aes-ccm
ssid Guest
ssid Work-Hard
antenna gain 0
station-role root
no dot11 extension aironet
interface Dot11Radio0.102
encapsulation dot1Q 102 native
no ip route-cache
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface Dot11Radio0.112
encapsulation dot1Q 112
no ip route-cache
bridge-group 112
bridge-group 112 subscriber-loop-control
bridge-group 112 block-unknown-source
no bridge-group 112 source-learning
no bridge-group 112 unicast-flooding
bridge-group 112 spanning-disabled
interface Dot11Radio1
no ip address
no ip route-cache
ssid Guest
ssid Work-Hard
antenna gain 0
no dfs band block
channel dfs
station-role root
interface Dot11Radio1.102
no ip route-cache
bridge-group 1
interface Dot11Radio1.112
no ip route-cache
bridge-group 112
interface GigabitEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
no keepalive
interface GigabitEthernet0.102
no ip route-cache
bridge-group 1
interface GigabitEthernet0.112
no ip route-cache
bridge-group 112
interface BVI1
ip address 172.20.2.8 255.255.255.0
no ip route-cache
ip default-gateway 172.20.2.1
no ip http server
ip http secure-server
ip http help-path
http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
ip radius source-interface BVI1
radius-server host 172.20.0.110 auth-port 1645 acct-port 1646 key 7 121A0C041104
bridge 1 route ip
alias exec sr show run
alias exec cr copy run start
alias exec b sho ip int brief
alias exec t conf t
line con 0
logging synchronous
login authentication CON
line vty 0 4
exec-timeout 30 0
privilege level 15
login authentication VTY
transport preferred ssh
transport input ssh
transport output ssh
line vty 5 15
exec-timeout 30 0
privilege level 15
transport input ssh
sntp server 132.163.4.101
end
Any help or assistance is greatly appreciated.
Let me know what if any more details would help with this.
David P.
Everyone's tags (4)
1 REPLY
Hall of Fame Super Gold
Hi Dave,
Log shows the client lost connection because it has left the range from the radio.  The radio is 802.11b/g and your configuration is showing you have enabled all the data rates.
So what I would like to know is this:  How far are you from the WAP and what is the signal strength you are seeing from the client?
1092
