LAN Network and AP network can be same- Cisco 1941 Router
I have my Lan user users conned to interface Gigabitethernet 0/0(network 192.168.10.0). DHCP is configured on the server. Now i want to configure WLAN and wants user should also get the ip address from the same network. Otherwise user getting connected with WLAN would have different network add.
so, i cannot give the same ip range to my vlan interface as i have already given to interface Gigabitethernet 0/0. Any chance that Wired and Wireless users should get the same IP range (192.168.10.0) so that they can communicate to each other. I hope you got my point.
Everyone's tags (4)
Re: LAN Network and AP network can be same- Cisco 1941 Router
Anyone please....
ok..
lemme think!!!
assuming we have mapped gig 0/0 for vlan 1.. then..if we have interface vlan 1 on the router..
then under the wlap ap 0 interface, issue the command "ip unnumbered vlan 1"
that is..
if..
int vlan 1
ip add 192.168.10.X 255.255.255.0
then..
int wlan-ap 0
no shut
session into the AP module and assing the IP address to the BVI in the same subnet of vlan 1..
then open up the GUI of the AP and configure for the desired configurations..
This will give the wired and wireless to be in the same subnet.
Surendra
First of all, thnx for ur reply.
int vlan 1
The above ip range can not be given to LAN interface on same router also. How is it possible from GUI??? why not from CLI???
We need to think logic that On a router we can not give same ip subnet (in our case 192.168.10.x / 24) to vlan 1 (default gateway of my Wireless users) and int gigabitethernet 0/X ( default gateway of my wired users). Is ther any other way to meet my requirement. Thanks
ok.. if we move all the configurations which is der inside the gig to vlan 1 then map the vlan to the gig.. so there will be only one interface vlan in the network.
I hope the above was clear.. if not i request you to paste the config..
Surendra
ip dhcp pool WLAN
   network 192.168.10.X 255.255.255.0
   default-router 192.168.10.X
   dns-server X.X.X.X
interface Wlan-GigabitEthernet0/0
description Internal switch interface connecting to the embedded AP
switchport mode trunk
interface GigabitEthernet0/0 (You are saying to remove config from here?)
description Connected to LAN
ip address 192.168.10.x 255.255.255.0
ip nat inside
ip virtual-reassembly
duplex auto
speed auto
interface wlan-ap0
description Service module interface to manage the embedded AP
ip unnumbered Vlan1
arp timeout 0
no mop enabled
no mop sysid
interface GigabitEthernet0/1
description Connected to WAN
ip address dhcp
ip nat outside
duplex auto
speed auto
interface Vlan1 (We will use only this interface for both wired and wireless users?)
description User coming from AP
ip nat inside
On AP Side
interface BVI1
ip address 192.168.1.3 255.255.255.0
no ip route-cache
Can you give me config after modification you are suggesting ????
it will be really great if you could open up a TAC case for this issue.. and the commands are der in the config guide which i provided before.
Surendra
how to open TAC case for this issue ??? I am new to this community. Can you help me in this regard???
is the device under contract or under warranty?? if so, then contact the Cisco TAC toll free number.. telling wireless config assistance
http://www.cisco.com/en/US/support/tsd_cisco_worldwide_contacts.html
Surendra
1800
