Community Member
LAP not joining WLC
i am using WLC 2106 with 5.1 version and trying to connect LAP 1232 to wlc.when i connect the lap to POE switch and wlc in same switch,lap is able to connect to WLC but when i am connecting the LAP directly to WLC (port 7/8) AP is not joining the wlc.
when i give the command debug lwapp events enable/debug lwapp packets enable and restart the LAP (after plugging off the lap cable and connecting back) not getting any output on WLC.
is it teh case that WLC not able to provide sufficient power to AP.i dont have external power supply to connect lap to any other port on WLC.
Also even after making the LAP default after using MODE button, still it asks for the username..what woule be the username here.tried cisco/cisco but not working..
Please respond..
1 REPLY
Silver
Re: LAP not joining WLC
Power's not the problem for a 1230- if it were a 1250 that would be a different story.
In the Ports menu on the controller, how do you have your POE ports configured?
367
