LAP will not Join 2106 Controller
This is driving me nuts!
I am trying to get one AP to join the 2106 controller, it did join once then never again!!  Now all I get is:
*Jan 22 11:16:22.088: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to administratively down
*Jan 22 11:16:22.088: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to administratively down
*Jan 22 11:16:22.091: %LINK-3-UPDOWN: Interface Dot11Radio0, changed state to up
*Jan 22 11:16:22.098: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*Jan 22 11:16:22.106:  status of voice_diag_test from WLC is false
*Jan 22 11:16:22.106: %LINK-3-UPDOWN: Interface Dot11Radio1, changed state to up
*Jan 22 11:16:22.127: %LINK-3-UPDOWN: Interface Dot11Radio0, changed state to up
*Jan 22 11:16:32.105: %CAPWAP-3-ERRORLOG: Go join a capwap controller
*Jan 22 11:16:32.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 172.31.228.147 peer_port: 5246
*Jan 22 11:16:32.000: %CAPWAP-5-CHANGED: CAPWAP changed state to
It just stops at this point, Help ??
  • Getting Started with Wireless
Missed a bit off:
*Jan 22 11:20:31.999: DTLS_CLIENT_ERROR: ../dtls/dtls_connection_db.c:2015 Max retransmission count reached!
*Jan 22 11:20:31.999: %DTLS-3-HANDSHAKE_RETRANSMIT: Max retransmit count for 172.31.228.147 is reached.
*Jan 22 11:21:01.999: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 172.31.228.147:5246
*Jan 22 11:21:02.039: %CAPWAP-5-CHANGED: CAPWAP changed state to DISCOVERY
*Jan 22 11:21:02.088: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to administratively down
*Jan 22 11:21:02.088: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to administratively down
*Jan 22 11:21:02.098: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*Jan 22 11:21:02.106: %CAPWAP-5-STATIC_TO_DHCP_IP: Could not discover WLC using static IP. Forcing AP to use DHCP.
*Jan 22 11:21:02.121:  status of voice_diag_test from WLC is false
You have mentioned it has joined once, can you check the following
1. The port 5246 and 5247 are opened between the AP and the WLC
2. Both AP and WLC are having the same country code config
Please mention the AP model and the images running in the WLC
NikhiL
mostly this happened when we have mismatched ragulatory domain so please check the country code in your controller and configure as your country name
your LAPs will join the controllers
let me know if this answered your question
don't forget to rate if this answered you
This is a new site in South America, I am trying to set it up from the UK.
The controllers 2106's are on 7.0.98.0
The AP's are AIR-LAP1142N-T-K9
We are running L3 to the edge, the controllers are connected to the distribution switches (4900) and the APs are conncected to 4506 and 3560X.
I am being really thck I guess, but if I connect a port to the 4506 the AP's connect, if I leave them just connected to the 4900 they try and join but this is as far as it goes:
AP Debug:
*Jan 23 10:26:45.000: DTLS_CLIENT_ERROR: ../dtls/dtls_connection_db.c:2015 Max retransmission count reached!
*Jan 23 10:26:45.000: %DTLS-3-HANDSHAKE_RETRANSMIT: Max retransmit count for 172.31.228.66 is reached.
*Jan 23 10:27:14.999: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 172.31.228.66:5246
*Jan 23 10:27:15.044: %CAPWAP-5-CHANGED: CAPWAP changed state to DISCOVERY
*Jan 23 10:27:15.045: %CAPWAP-5-CHANGED: CAPWAP changed state to DISCOVERY
*Jan 23 10:27:15.099: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to administratively down
*Jan 23 10:27:15.099: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to administratively down
*Jan 23 10:27:15.109: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*Jan 23 10:27:15.118:  status of voice_diag_test from WLC is false
*Jan 23 10:27:15.119: %LINK-3-UPDOWN: Interface Dot11Radio1, changed state to up
*Jan 23 10:27:15.140: %LINK-3-UPDOWN: Interface Dot11Radio0, changed state to up
*Jan 23 10:27:15.140: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to reset
*Jan 23 10:27:25.118: %CAPWAP-3-ERRORLOG: Selected MWAR 'LCGRCWCB'(index 0).
*Jan 23 10:27:25.118: %CAPWAP-3-ERRORLOG: Go join a capwap controller
*Jan 23 10:29:30.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 172.31.228.82 peer_port: 5246
*Jan 23 10:29:33.000: %CAPWAP-5-CHANGED: CAPWAP changed state to
*Jan 23 10:30:10.000: DTLS_CLIENT_ERROR: ../dtls/dtls_connection_db.c:2015 Max retransmission count reached!
*Jan 23 10:30:10.000: %DTLS-3-HANDSHAKE_RETRANSMIT: Max retransmit count for 172.31.228.82 is reached.
spamReceiveTask: Jan 23 10:22:58.671: 64:a0:e7:b0:19:90 Discovery Request from 172.31.228.83:39043
*spamReceiveTask: Jan 23 10:22:58.671: 64:a0:e7:b0:19:90 Join Priority Processing status = 1, Incoming Ap's Priority 1, MaxLrads = 6, joined Aps =0
*spamReceiveTask: Jan 23 10:22:58.671: 64:a0:e7:b0:19:90 Discovery Response sent to 172.31.228.83:39043
*spamReceiveTask: Jan 23 10:22:58.672: 64:a0:e7:b0:19:90 Discovery Request from 172.31.228.83:39043
*spamReceiveTask: Jan 23 10:22:58.672: 64:a0:e7:b0:19:90 Join Priority Processing status = 1, Incoming Ap's Priority 1, MaxLrads = 6, joined Aps =0
*spamReceiveTask: Jan 23 10:22:58.672: 64:a0:e7:b0:19:90 Discovery Response sent to 172.31.228.83:39043
*spamReceiveTask: Jan 23 10:23:43.926: 64:a0:e7:ae:43:90 Discovery Request from 172.31.228.88:39041
*spamReceiveTask: Jan 23 10:23:43.926: 64:a0:e7:ae:43:90 Join Priority Processing status = 1, Incoming Ap's Priority 1, MaxLrads = 6, joined Aps =0
*spamReceiveTask: Jan 23 10:23:43.926: 64:a0:e7:ae:43:90 Discovery Response sent to 172.31.228.88:39041
*spamReceiveTask: Jan 23 10:23:43.927: 64:a0:e7:ae:43:90 Discovery Response sent to 172.31.228.88:39041
Controler Debug:
can you put the show inventory from the wlc
(lcgrcwcb) >show inventory
Burned-in MAC Address............................ 30:E4:DB:32:49:20
NAME: "Chassis"    , DESCR: "2100 Series WLAN Controller:6 APs"
PID: AIR-WLC2106-K9,  VID: V05,  SN: JMX153840L4
There are two controllers but I have downed one just to get one working as they are doing the same thing ;-0
sry, i missed out one more show command
show country in wlc
and then put 2 debug command in the WLC, debug client :ap-base-radio-mac" and debug capwap events enable
NikhiL
(lcgrcwcb) >show country in wlc
Configured Country............................. US  - United States
Configured Country Codes
        US  - United States............................. 802.11a Indoor,Outdoor / 802.11b / 802.11g
LAP:
*Mar  1 00:13:02.026: %CAPWAP-3-ERRORLOG: Could Not resolve CISCO-CAPWAP-CONTROLLER.lac.uis.unisys.com
*Mar  1 00:13:12.027: %CAPWAP-3-ERRORLOG: Selected MWAR 'LCGRCWCB'(index 0).
*Mar  1 00:13:12.027: %CAPWAP-3-ERRORLOG: Go join a capwap controller
*Jan 23 11:46:14.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 172.31.228.82 peer_port: 5246
*Jan 23 11:46:16.999: %CAPWAP-5-CHANGED: CAPWAP changed state to
*Jan 23 11:46:53.999: DTLS_CLIENT_ERROR: ../dtls/dtls_connection_db.c:2015 Max retransmission count reached!
*Jan 23 11:46:53.999: %DTLS-3-HANDSHAKE_RETRANSMIT: Max retransmit count for 172.31.228.82 is reached.
*Jan 23 11:47:13.999: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 172.31.228.82:5246
*Jan 23 11:47:17.000: %CAPWAP-3-ERRORLOG: Selected MWAR 'LCGRCWCB'(index 0).
*Jan 23 11:47:17.000: %CAPWAP-3-ERRORLOG: Go join a capwap controller
*Jan 23 11:46:54.000: DTLS_CLIENT_ERROR: ../dtls/dtls_connection_db.c:2015 Max retransmission count reached!
*Jan 23 11:46:54.000: %DTLS-3-HANDSHAKE_RETRANSMIT: Max retransmit count for 172.31.228.82 is reached.
*Jan 23 11:47:17.045: %CAPWAP-5-CHANGED: CAPWAP changed state to DISCOVERY
*Jan 23 11:47:17.105: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to administratively down
*Jan 23 11:47:17.105: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to administratively down
*Jan 23 11:47:17.108: %LINK-3-UPDOWN: Interface Dot11Radio0, changed state to up
*Jan 23 11:47:17.115: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*Jan 23 11:47:17.125:  status of voice_diag_test from WLC is false
*Jan 23 11:47:17.125: %LINK-3-UPDOWN: Interface Dot11Radio1, changed state to up
*Jan 23 11:47:17.146: %LINK-3-UPDOWN: Interface Dot11Radio0, changed state to up
*Jan 23 11:47:17.146: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to reset
*Jan 23 11:47:27.124: %CAPWAP-3-ERRORLOG: Selected MWAR 'LCGRCWCB'(index 0).
*Jan 23 11:47:27.124: %CAPWAP-3-ERRORLOG: Go join a capwap controller
*Jan 23 11:48:30.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 172.31.228.82 peer_port: 5246
*Jan 23 11:48:33.000: %CAPWAP-5-CHANGED: CAPWAP changed state to
*Jan 23 11:49:10.000: DTLS_CLIENT_ERROR: ../dtls/dtls_connection_db.c:2015 Max retransmission count reached!
*Jan 23 11:49:10.000: %DTLS-3-HANDSHAKE_RETRANSMIT: Max retransmit count for 172.31.228.82 is reached.
*Jan 23 11:49:29.999: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 172.31.228.82:5246
*Jan 23 11:49:33.000: %CAPWAP-3-ERRORLOG: Selected MWAR 'LCGRCWCB'(index 0).
*Jan 23 11:49:33.000: %CAPWAP-3-ERRORLOG: Go join a capwap controller
lcgrcwcb) >*spamReceiveTask: Jan 23 11:46:14.614: 64:a0:e7:b0:19:90 Discovery Request from 172.31.228.83:39042
*spamReceiveTask: Jan 23 11:46:14.614: 64:a0:e7:b0:19:90 Join Priority Processing status = 1, Incoming Ap's Priority 1, MaxLrads = 6, joined Aps =0
*spamReceiveTask: Jan 23 11:46:14.615: 64:a0:e7:b0:19:90 Discovery Response sent to 172.31.228.83:39042
*spamReceiveTask: Jan 23 11:46:14.615: 64:a0:e7:b0:19:90 Discovery Request from 172.31.228.83:39042
*spamReceiveTask: Jan 23 11:46:14.616: 64:a0:e7:b0:19:90 Join Priority Processing status = 1, Incoming Ap's Priority 1, MaxLrads = 6, joined Aps =0
*spamReceiveTask: Jan 23 11:46:14.616: 64:a0:e7:b0:19:90 Discovery Response sent to 172.31.228.83:39042
*spamReceiveTask: Jan 23 11:48:30.727: 64:a0:e7:b0:19:90 Discovery Request from 172.31.228.83:39043
*spamReceiveTask: Jan 23 11:48:30.727: 64:a0:e7:b0:19:90 Join Priority Processing status = 1, Incoming Ap's Priority 1, MaxLrads = 6, joined Aps =0
*spamReceiveTask: Jan 23 11:48:30.727: 64:a0:e7:b0:19:90 Discovery Response sent to 172.31.228.83:39043
*spamReceiveTask: Jan 23 11:48:30.728: 64:a0:e7:b0:19:90 Discovery Request from 172.31.228.83:39043
*spamReceiveTask: Jan 23 11:48:30.728: 64:a0:e7:b0:19:90 Join Priority Processing status = 1, Incoming Ap's Priority 1, MaxLrads = 6, joined Aps =0
*spamReceiveTask: Jan 23 11:48:30.728: 64:a0:e7:b0:19:90 Discovery Response sent to 172.31.228.83:39043
(lcgrcwcb) >*spamReceiveTask: Jan 23 11:50:46.832: 64:a0:e7:b0:19:90 Discovery Request from 172.31.228.83:39042
*spamReceiveTask: Jan 23 11:50:46.832: 64:a0:e7:b0:19:90 Join Priority Processing status = 1, Incoming Ap's Priority 1, MaxLrads = 6, joined Aps =0
*spamReceiveTask: Jan 23 11:50:46.832: 64:a0:e7:b0:19:90 Discovery Response sent to 172.31.228.83:39042
*spamReceiveTask: Jan 23 11:50:46.833: 64:a0:e7:b0:19:90 Discovery Request from 172.31.228.83:39042
*spamReceiveTask: Jan 23 11:50:46.833: 64:a0:e7:b0:19:90 Join Priority Processing status = 1, Incoming Ap's Priority 1, MaxLrads = 6, joined Aps =0
*spamReceiveTask: Jan 23 11:50:46.833: 64:a0:e7:b0:19:90 Discovery Response sent to 172.31.228.83:39042
Controller:
4176
