Community Member
LAP1142 with different regulatory domains on each wireless
Hi, I wonder if anyone has come across this before:
We've seen an AIR-LAP1142-E-K9 wireless access point - one of a batch on the pre-used market although I understand that they have been simply removed from the original user - where the regulatory domain on each of the radios is different.
The 2.4GHz radio is 802.11bg:-E and the 5GHz radio is 802.11a:-A (as reported by the controller).
This is really strange as the AP shows itself to be the Product/Model Number             : AIR-LAP1142N-E-K9
And the radio circuit board contains the circuitry for both radios so it's not that the wrong board has been installed for the A radio.
I don't know the software version that is running on the controller - and I've tried a bug search but that hasn't turned up anything useful (yet).
Has anyone here seen anything like this or offer any explanation?
Thanks in advance
Robin
Hall of Fame Super Silver
That is not right.  If you
That is not right.  If you look at the model number on the sticker on the bottom of the AP, that sticker will tell you what regulatory domain that AP is built for.
Scott
-Scott
Community Member
I know it is not right.  I
I know it is not right.  I don't have the AP in front of me, but the information given to me says that the AP reports that it is built for -E-  however on the WLC it reports -E on the one radio and -A on the other - see the attachment.
Hall of Fame Super Gold
That's not where to look for
That's not where to look for the Regulatory Domain of your AP.
Go to Monitor > Summary > All APs > Detail.
Choose the AP and go to Inventory tab.  First line, Product ID, should tell you what the Regulatory Domain of your AP.
Netherland is -E per this doc
Netherland is -E per this doc:
http://www.cisco.com/c/en/us/products/collateral/wireless/aironet-1300-series/product_data_sheet0900aecd80537b6a.html
why you have an AP with different radios, I don't know, because the sticker is what comes from the factory and is suppose to have those radios for that regulatory domain.  Maybe someone swapped the radios:)
Scott
-Scott
Community Member
That's what I thought, Scott,
That's what I thought, Scott, but I've had one of these to pieces and both radios are driven from the one circuit board...
I did wonder if there was a bug in the firmware level on the WLC but I don't have access to it to check.  Especially since others from the same batch are reported to have worked without problems - we ourselves have had some - and they are reported to have worked fine in their original installation (these are pre-owned units).
Oh well, I guess this will remain a mystery.  Thanks to everyone who replied.
Robin
48
