Laptop not able to get the wireless signal from the lightweightAP
Brief idea of the installation.
One WLC 5500 active -> second not yet installed
36 AP active, at the end they will be 45 (9 not installed)
Everything on the configuration look active and the light AP are registred to th
e WLC.
RF Channel definition done by WLC on all AP
Power definition done by WLC on all AP
Detection of rouge AP
But the laptops can't even detect the RF signal.
I try to detect the signal with 2 laptop which they where working in other sites with wireless in place.
We ara using 3 different application or client: Ippass, Odyssey, wiresquark Any of this application detect the signal.
However, on the WLC and on the light AP are up and running. Status up, channel and power automatic definition.
On the log I can see the detection of some Rouge AP around.
1 REPLY
Hall of Fame Super Gold
Re: Laptop not able to get the wireless signal from the lightwei
Did you enable "Broadcast SSID"?
207
