Laptops can`t ping each other on the same SSID
Hi guys,
Iam having issue with Wireless Lan.
For some reason my Laptops in the same SSID can`t ping each other.
But they can ping default gateway->can go to the internet.
Somone know what is the problem?
  • Getting Started with Wireless
There could be any number of several factors at play here, from the wireless access point configured to not allow inter-device communications, to Windows Firewall (Linux iptables, etc.) blocking ICMP.  The latter can be easily verified with a back-to-back connection between the laptops (using a cross-over cable).
Can you provide some additional details regarding the equipment and software in use?
Best,
Ed
Hall of Fame Super Silver
Re: Laptops can`t ping each other on the same SSID
Do you have peer to peer blocking enabled? Is this autonomous or lightweight?
Thanks, Scott *****Help out other by using the rating system and marking answered questions as "Answered"*****
thanks for the fast replay guys.
Scott- No we dont have peer-to -peer blocking.
Edwin-how i can check the inter device communication?
because when i connect the same pc`s to the wired network, they can ping each other.
when they go to the wireless network.-> they cant..
Regards.
Liad,
     I'd check to see if the windows firewall is enabled on the wireless interface.
HTH,
Steve
Please remember to rate helpful posts or to mark the question as answered so that it can be found later.
HTH, Steve ------------------------------------------------------------------------------------------------ Please remember to rate useful posts, and mark questions as answered
Stephen,
How do i check it?
I can see that windows firewall is enabled, but allowing ICMP traffic.
I put allow any just to try, and still didnt work.
It sounds odd, but instead of allowing can you disable the windows firewall on the wireless interface?
What device are you using as your wireless access point?
Variance .
1131AG
1242
1042-mostly
1142
So when you have two users on the same AP, the devices can't ping each other.  Or is it an issue when they are on different AP's?
1782
