11-07-2006 12:32 PM - edited 07-03-2021 01:12 PM
What does it mean when the radio light is a constant green?
11-07-2006 01:53 PM
Hi Joy,
Hopefully these are the guides you are looking for, if I missed the one you need let me know.
Cisco Aironet 1000 Series Lightweight Access Point Hardware Installation Guide
Checking the Access Point LEDs
Cisco Aironet 1100 Series Access Point Hardware Installation Guide,
Checking the Lightweight Access Point LEDs
Checking the Autonomous Access Point LEDs
Cisco Aironet 1240AG Series Access Point Hardware Installation Guide
Troubleshooting 1240AG Series Autonomous Access Points / Checking the Top Panel LEDs
Cisco Aironet 1200 Series Access Point Hardware Installation Guide
Troubleshooting Autonomous Access Points / Checking the Top Panel LEDs
Hope this helps!
Rob
Please remember to rate helpful posts.....
11-08-2006 06:42 AM
As noted in other threads on the forum, if you are using the lightweight version of the AP, there is an error condition where the AP LED on the LAP-1131AG access point LED will display the light green color (typically indicating normal operation) when it is unable to obtain an IP address via DHCP.
This is a known bug that Cisco is in the process of remediating.
- John
11-08-2006 11:46 AM
Thanks for the response. I was getting frustrated and should have been more specific, sorry. The AP is an Aironet 1200 series and it has a static IP. It has been in a territory "war" with another Cisco AP of which I have no control over. The other party set the other IP to broadcast over "a" only and that seemed to help a lot. Now I am trying to fine tune signal drops and disconnections. I noticed that at times the bottom (radio) light stays solid green and couldn't find out what that meant in the LED TS chart.
J. Wells
