LEDS on DOT11RADIO
Hello
Just looking at my card why is only the righthand side led light on?
Cheers
James
back to school!!
1 ACCEPTED SOLUTION
Hall of Fame Super Silver
Re: LEDS on DOT11RADIO
You should look at the guide for that device. I can't see what the led is for in the picture. The guide will have all that info.
-Scott
-Scott
Hall of Fame Super Gold
LEDS on DOT11RADIO
Or maybe one of the radios is disabled.
LEDS on DOT11RADIO
are you using the radio in repeater? if So , LED does go off if no client is connected
Bronze
The best way to check the LED status or purpose is to unplugged all the cables and plugged in one by one and you can also check the user manual of your wireless device .
This is basically a Packet Voice Digital Signal (PVDM) is a hardware  module that provides digital-signal-processor (DSP) resources to the  system. A PVDM module can be populated with one or more DSPs. The DSP  resources on a PVDM module provide collaboration services including  voice sessions, transcoding sessions, conference sessions, and video.
Please check the below link for configuration of Ports.
Link-1
http://www.cisco.com/en/US/prod/collateral/modules/ps3115/ps6024/prod_qas0900aecd8016c6ad_ps5855_Products_Q_and_A_Item.html
Link-2
http://www.cisco.com/en/US/prod/collateral/modules/ps3115/qa_c67_553073.html
LEDS on DOT11RADIO
Thanks for replys, think i will just carry on reading data sheets etc
back to school!!
LEDS on DOT11RADIO
There you go... From the pic it was hard to figure out what device/module it was and that is why I mentioned to look at the guide. Glad you found it.
-Scott
180
