07-17-2014 12:25 PM - edited 07-05-2021 01:14 AM
When I am tftping the new IOS it suddenly times out, I then see that the static ip address that I set on Gi0 is gone and "ip address dhcp client-id GigabitEthernet0" is back in the interface config. Question is how do I stop this happening so I can complete IOS tftp transfer
Solved! Go to Solution.
07-18-2014 08:32 AM
Do this:
Note some of these are hidden commands, Meaning TAB does not work :)
on LWAPP AP:
debug capwap console cli -CLI Mode
debug capwap cli no-reload -stops it reloading
**Assign IP:
capwap ap ip address <IP> <SM>
capwap ap default-gateway <IP of your TFTP Server/typically your PC>
**Transfer
archive /download-sw tftp://<IP>/filename.tar
07-17-2014 01:07 PM
Set IP on Interface Gi0 and also configure default gateway.
If its changing frequently then configure above steps and save it.
then follw this method:
http://rscciew.wordpress.com/2014/05/07/access-point-conversion-lap-to-aap-and-vice-versa/
http://www.youtube.com/watch?v=QQ_NuxdRhQ4
07-18-2014 07:20 AM
Hi Sandeep
doesnt save config I get..
APf866.f244.72b8#wr mem
Building configuration...
[OK]
NVRAM Verification Failed
It just keeps forcing the DHCP config on
07-18-2014 08:32 AM
Do this:
on LWAPP AP:
**Assign IP:
**Transfer
07-18-2014 08:51 AM
Thank you Isagabrillo, thats fixed it, for two days I've been struggleing with that!
The no-reload command I think was the fixer!
thanks again
and thanks to Sandeep too :)
07-18-2014 08:58 AM
Glad to help :)
