poz
LWAPP switch port configuration
Ok, I have seen some lwapp configurations threads that describe the switch port conifg but not in detail. What is the recommended port configuration for an LWAPP? the macro-wireless is still active in the latest IOS versions buth the recommended website: http://www.cisco.com/web/go/smartports/index.html link is broken. is there a macro for LWAPP? should you enable port secuirty on an LWAPP port? is this a good idea? I know the basic config is any vlan that is routed to WLC I used the example at : http://www.cisco.com/application/pdf/paws/69719/wlc_lwap_config.pdf
Im looking for Cisco recommended best practices info for port configuration ont 3750 advip, any help is appreciated
1 REPLY
Re: LWAPP switch port configuration
The smartport macro is for an autonomous AP
If you do a "show parser macro" you will see the definitions for all the built-in macros
here is the wireless one
Macro name : cisco-wireless
Macro type : default interface
# macro keywords $native_vlan
# Access Uplink to Distribution
# Define unique Native VLAN on trunk ports
# Recommended native vlan should NOT be 1
switchport trunk native vlan $native_vlan
# Update the allowed VLAN range such that it
# includes data, voice and native VLANs
switchport trunk allowed vlan ALL
# Hardcode trunk and disable negotiation to speed up convergence
switchport mode trunk
switchport nonegotiate
# Configure qos to trust this interface
auto qos voip trust
mls qos trust cos
# Ensure that switch devices cannot become active on the interface.
spanning-tree bpduguard enable
Here is a port config for an lwapp AP
H113#sh running-config interface gigabitEthernet 0/46
Building configuration...
Current configuration : 299 bytes
interface GigabitEthernet0/46
description MR1 AP
switchport access vlan 80
switchport mode access
priority-queue out
mls qos trust dscp
You can build a macro and apply it to an interface or range of interfaces
conf t
macro name LWAPP-ap
priority-queue out
cdp enable
speed auto
duplex auto
spanning-tree portfast
spanning-tree bpdufilter enable
int range gi 0/12 - 15
macro apply LWAPP-AP
end
2967
