Macintosh can't connect Using Flexconnect/H-REP and Localy switched vlans
Hi!
I have about 200 APs (Cisco 1042n and 1142n), 4 controllers (5508 and 2504).. Switches are 2960s and some other stuff..
I Use NCS for management.
We have a couple of vlans and SSIDs, when users connect to a SSID i use Flexconnect to associate the users to the correct VLAN..
The APs are connected using the following setup in the switch:
interface GigabitEthernet1/0/20
description Accesspoints
switchport trunk native vlan 3
switchport trunk allowed vlan 2-4,10-13
switchport mode trunk
Here is a image from my Flexconnect setting on the AP..
It works nice with a PC but not on a Macintosh (ssid on vlan 3 works)...
Security level are wpa2, tkip, psk..
Everyone's tags (4)
WPA2 should be AES not TKIP.  Try making that change to the WLAN and see if the OS X devices are able to connect
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
HTH, Steve ------------------------------------------------------------------------------------------------ Please remember to rate useful posts, and mark questions as answered
Re: Macintosh can't connect Using Flexconnect/H-REP and Localy s
I know AES is preffered but its not the cause to the problem in this case..
I can connect to WPA2 TKIP + PSK using macintosh if i dont use Flexconnect and local switching
Hall of Fame Super Silver
Well my Mac book, iPhone and iPad will not connect if I use either of the following:
wpa/aes
woa/aes/tkip
wpa2/tkip
wpa2/aes/tkip
Only works if it's set to these
wpa/tkip
wpa2/aes
-Scott
You need to push out a new SSID for testing, set it for wpa/tkip or wpa2/aes and see if the clients connect fine. If they do, then you know what needs to be changed on your existing SSIDs.
-Scott
Any wireless device that doesn't work on wpa-aes and or wpa2-tkip, irrespective of that config available on the supplicant or not, are doesn't matter since those settings are not tested as part of wifi certification.
424
