07-15-2012 06:57 AM - edited 07-03-2021 10:24 PM
Hi everybody
Let say we have two buildings, B1 and B2. We want to connect them using cisco work group bridges using wireless.
B1(work group bridge1) ====wireless link========(work group bridge 2)
My questions are:
what are my options when it comes to choosing cisco work group bridges supporting 802.11 standards only ?
What are my options when it comes to choosing Antenna?( Assuming we do have clear line of sight)
thanks and have great weekend.
Solved! Go to Solution.
07-15-2012 07:37 AM
What you really need is a point to point bridge on each end. You can't connect two WGB together and most likely you will need the radio/antennas to be mounted outside with cabling running inside the building. Cisco resells the Exalt r5005 bridges which has a max throughput of 160mbps half duplex. Or you can go with the 1400 bridges witch are EOS/EOL I believe.
07-15-2012 10:34 AM
No problem. It's better that you look at bridging technologies. There are a lot out there and some even go up to gigabit full duplex.
07-15-2012 10:41 AM
By the way, most bridge manufacture will have some sort of outdoor bridge calculator that can give you an idea of your throughput, fresnel zone, etc.
07-15-2012 03:13 PM
07-15-2012 07:37 AM
07-15-2012 09:29 AM
Thanks Scott.
07-15-2012 10:34 AM
07-15-2012 10:41 AM
07-15-2012 03:13 PM
