Max power
Can someone tell me what is the max tx power for a 1252 and 1142 (US model) access point @ both 2.4 GHz and 5 GHZ?
Re: Max power
The max transmit power on the 1252's and 1142's shoudl be as follows:
802.11b = 20dbm = 100mw
802.11g = 17dbm = 50mw
802.11a = 17dbm = approx. 40mw
This isn't so much a limit of the access point as it is a limit of the FCC Regulations which limits indoor wireless to 1watt maximum EIRP, for more information on this check FCC Part 15.247
Hope this helps.
Re: Max power
Although true... But check out what I blogged about on my site running a debug while on UNII 1/2/3. Depending on the band, the FCC limits power... So if you select channel 36 vs 161 ... There is different TX power...
http://www.my80211.com/cisco-wlc-labs/2009/10/30/what-you-need-to-know-about-tx-power-and-80211a-5ghz-on-a-ci.html
__________________________________________________________________________________________ "Satisfaction does not come from knowing the solution, it comes from knowing why." - Rosalind Franklin ___________________________________________________________
282
