mbssid not working on ap802
hello everyone,
i have this strange problem since upgrading to latest IOS -
ap802-k9w7-tar.152-4.JB3a.tar, mbssid is not working.
here is the ap config:
conf t
version 12.4
no service pad
Hostname ap
enable secret Cisco
no aaa new-model
Dot11 mbssid
dot11 vlan-name vlan20 vlan 20
dot11 ssid test
vlan 20
authentication open
authentication key-management wpa version 2
mbssid guest-mode
wpa-psk ascii 12345678
dot11 vlan-name vlan30 vlan 30
dot11 ssid test-2
vlan 30
authentication open
mbssid guest-mode
Bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
no shutdown
mbssid
Encryption vlan 20 mode ciphers aes-ccm
Encryption vlan 30 mode ciphers aes-ccm
ssid test
ssid test-2
station-role root
bridge-group 1
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface Dot11Radio0.20
encapsulation dot1Q 20
no ip route-cache
bridge-group 20
bridge-group 20 subscriber-loop-control
bridge-group 20 block-unknown-source
no bridge-group 20 source-learning
no bridge-group 20 unicast-flooding
bridge-group 20 spanning-disabled
interface Dot11Radio0.30
encapsulation dot1Q 30
no ip route-cache
bridge-group 30
bridge-group 30 subscriber-loop-control
bridge-group 30 block-unknown-source
no bridge-group 30 source-learning
no bridge-group 30 unicast-flooding
bridge-group 30 spanning-disabled
interface GigabitEthernet0
description the embedded AP GigabitEthernet 0 is an internal interface connecting AP with the host router
no ip address
no ip route-cache
bridge-group 1
interface GigabitEthernet0.20
no ip route-cache
bridge-group 20
interface GigabitEthernet0.30
no ip route-cache
bridge-group 30
interface BVI1
ip address dhcp client-id GigabitEthernet0
no ip route-cache
ip http server
ip http authentication local
no ip http secure-server
bridge 1 route ip
line con 0
no activation-character
line vty 0 4
privilege level 15
login local
End
i am using this template for all my ap's (mostly 880 series).
only the first ssid is broadcasted, any idea anyone?
1 ACCEPTED SOLUTION
Hall of Fame Super Silver
Re: mbssid not working on ap802
Matan,
Sometimes there is no reason to upgrade. V15.x does seem to break things when upgrading from v12.4. To me, v12.4 is a better version for now. I would implement the change and review the show run-config as configurations can change between code versions.
-Scott
1 REPLY
Matan,
-Scott
224
