Mesh 1252 disassociation
I am having problems during the implementation of two APs Mesh 1252.
RAP is working properly
MAP is disassociating approximately every 5 minutes.
RAP is connected with wired and MAP only RAP via radio 1 (5Ghz).
MAP is installed about 100 m of the RAP.
My customer is repoting, that the MAP is causing interference in other devices on 434.175 MHz frequence. It is possible?
What is the power loss that I see in the logs?
What is the Heartbeat Timeout that I see in the logs too?
0    Thu Feb 23 08:22:50 2012    Interference Profile Updated to Pass for Base Radio MAC: 00:08:30:bb:ec:00 and slotNo: 0
1    Thu Feb 23 08:19:17 2012    Rogue AP : 00:27:22:40:16:7d detected on Base Radio MAC : 2c:3f:38:59:6e:f0 Interface no:1(802.11n(5 GHz)) on Channel 153 with RSSI: -92 and SNR: 4 and Classification: unclassified
2    Thu Feb 23 08:12:35 2012    Mesh node '00:08:30:bb:db:20' joined parent node '00:08:30:bb:ec:0f' using default bridge group name.
3    Thu Feb 23 08:12:35 2012    AP's Interface:1(802.11a) Operation State Up: Base Radio MAC:00:08:30:bb:db:20 Cause=Radio reset due to Init. Status:NA
4    Thu Feb 23 08:12:35 2012    AP's Interface:0(802.11b) Operation State Down: Base Radio MAC:00:08:30:bb:db:20 Cause=Radio reset due to Init. Status:NA
5    Thu Feb 23 08:12:34 2012    AP 'BANDEIRANTEAP19', MAC: 00:08:30:bb:db:20 disassociated previously due to AP Reset. Uptime: 3 days, 17 h 06 m 45 s . Last reset reason: operator changed 11g mode.
6    Thu Feb 23 08:11:29 2012    AP Disassociated. Base Radio MAC:00:08:30:bb:db:20
7    Thu Feb 23 08:11:29 2012    AP's Interface:1(802.11a) Operation State Down: Base Radio MAC:00:08:30:bb:db:20 Cause=Heartbeat Timeout Status:NA
8    Thu Feb 23 08:11:26 2012    AAA Authentication Failure for UserName:c1520-000830BBDB20 User Type: WLAN USER
9    Thu Feb 23 08:11:26 2012    Mesh child node '00:08:30:bb:db:2f' has changed its parent to mesh node '00:08:30:bb:ec:00' from mesh node '00:08:30:bb:ec:0f'.
10    Thu Feb 23 08:10:49 2012    Interference Profile Failed for Base Radio MAC: 00:08:30:bb:ec:00 and slotNo: 0
11    Thu Feb 23 08:09:32 2012    Interference Profile Updated to Pass for Base Radio MAC: 00:08:30:bb:d9:e0 and slotNo: 0
12    Thu Feb 23 08:06:41 2012    Interference Profile Updated to Pass for Base Radio MAC: 2c:3f:38:59:6e:f0 and slotNo: 0
13    Thu Feb 23 08:06:32 2012    Interference Profile Failed for Base Radio MAC: 00:08:30:bb:d9:e0 and slotNo: 0
14    Thu Feb 23 08:00:32 2012    Interference Profile Failed for Base Radio MAC: 2c:3f:38:59:6e:f0 and slotNo: 0
15    Thu Feb 23 07:57:31 2012    Interference Profile Updated to Pass for Base Radio MAC: 00:08:30:bb:d9:e0 and slotNo: 0
16    Thu Feb 23 07:55:59 2012    Mesh node '00:08:30:bb:db:20' joined parent node '00:08:30:bb:ec:0f' using default bridge group name.
17    Thu Feb 23 07:55:59 2012    AP's Interface:1(802.11a) Operation State Up: Base Radio MAC:00:08:30:bb:db:20 Cause=Radio reset due to Init. Status:NA
18    Thu Feb 23 07:55:59 2012    AP's Interface:0(802.11b) Operation State Down: Base Radio MAC:00:08:30:bb:db:20 Cause=Radio reset due to Init. Status:NA
19    Thu Feb 23 07:55:59 2012    AP 'BANDEIRANTEAP19', MAC: 00:08:30:bb:db:20 disassociated previously due to AP Reset. Uptime: 3 days, 16 h 50 m 23 s . Last reset reason: power loss.
20    Thu Feb 23 07:55:20 2012    Mesh node '00:08:30:bb:db:2f' has changed its parent 5 times in last one hour.
21    Thu Feb 23 07:55:20 2012    Mesh child node '00:08:30:bb:db:2f' has changed its parent to mesh node '00:08:30:bb:ec:00' from mesh node '00:08:30:bb:ec:0f'.
22    Thu Feb 23 07:54:31 2012    Interference Profile Failed for Base Radio MAC: 00:08:30:bb:d9:e0 and slotNo: 0
23    Thu Feb 23 07:53:13 2012    Rogue AP : 00:27:22:40:16:7d removed from Base Radio MAC : 2c:3f:38:31:66:a0 Interface no:1(802.11a)
24    Thu Feb 23 07:53:13 2012    Rogue AP : 00:27:22:40:16:7d removed from Base Radio MAC : 2c:3f:38:59:6e:f0 Interface no:1(802.11a)
25    Thu Feb 23 07:48:31 2012    Rogue AP : 00:27:22:10:0d:75 detected on Base Radio MAC : 2c:3f:38:59:6e:f0 Interface no:1(802.11a) on Channel 149 with RSSI: -93 and SNR: 4 and Classification: unclassified
Can you help me?
Hall of Fame Super Silver
Re: Mesh 1252 disassociation
You should define a Bridgegroup name. When the MAP is joined, how is the signal? I don't think it will effect the other spectrum at all.
Scott Fella
Sent from my iPhone
-Scott
I already configured the Bridgegroup. AP is conected on AC power, then I already set PoE override. This MAP is joining to WLC, but each 5 or 10 minutes its is losing conectivity. When it loses the conectivity I see the following messages:
RAP ----------- about 120 meters ---------------- MAP (working properly)
         \                                             about 100 meters
            | ---------- about 100 meters ----------- MAP (losing join)
RAP working properly too
3 Thu Feb 23 18:45:34 2012 AP's Interface:1(802.11a) Operation State Up: Base Radio MAC:00:08:30:bb:db:20 Cause=Radio reset due to Init. Status:NA
4 Thu Feb 23 18:45:34 2012 AP's Interface:0(802.11b) Operation State Up: Base Radio MAC:00:08:30:bb:db:20 Cause=Radio reset due to Init. Status:NA
5 Thu Feb 23 18:45:32 2012 AP 'BANDEIRANTEAP19', MAC: 00:08:30:bb:db:20 disassociated previously due to AP Reset. Uptime: 4 days, 03 h 32 m 34 s . Last reset reason: power loss.
6 Thu Feb 23 18:44:54 2012 Mesh node '00:08:30:bb:db:2f' has changed its parent 5 times in last one hour.
what can be happening?
thanks and regards,
Murilo
768
