Mobility Groups and High Availability with WLC 5508s and 1240 APs
I have some questions about mobility groups and high availability in the context of WLC 5508s and 1240 APs.  We have two 5508s with identical images and licenses deployed in our environment.  A mobility group has been configured between them and it is up and running.  The configs are nearly identical; the only exception being the IP addresses associated with the interfaces.  There are 23 APs in our environment, and all are registered with the primary WLC.  I have configured HA on the HA tab of all the APs registered with the primary WLC.  All of the APs are operating as lightweight APs.  None of the APs have registered with the secondary WLC.  Here are my questions:
1.  Should the APs register with both WLCs given the above scenario?
2.  If the APs do not register with both WLCs, what needs to be done to get them to register with the second WLC?
3.  Will the APs register with the second WLC only if the primary fails?
4.  Is there a way to verify the HA config prior to a failover test?
Thanks in advance for any information you can provide.  If you have a link to documentation that explains the relationship between mobility groups and HA, please post it.  I checked CCO, but could not find any such document.
MB
PS:  Here are the pertinent sections of the WLC config
(Cisco Controller) >show mobility summary
Symmetric Mobility Tunneling (current) .......... Enabled
Symmetric Mobility Tunneling (after reboot) ..... Enabled
Mobility Protocol Port........................... 16666
Default Mobility Domain.......................... HPS_Mobility
Multicast Mode .................................. Enabled
Mobility Domain ID for 802.11r................... 0x2685
Mobility Keepalive Interval...................... 10
Mobility Keepalive Count......................... 3
Mobility Group Members Configured................ 2
Mobility Control Message DSCP Value.............. 0
Controllers configured in the Mobility Group
MAC Address        IP Address       Group Name                        Multicast IP     Status
44:d3:ca:b7:26:00  172.21.1.19      HPS_Mobility                      239.255.255.21   Up
e0:5f:b9:46:10:c0  172.21.1.18      HPS_Mobility                      239.255.255.21   Up
(Cisco Controller) >show ap config general HPSP_AP_4EC
Primary Cisco Switch Name........................ hps_wireless_ctr01
Primary Cisco Switch IP Address.................. 172.21.1.18
Secondary Cisco Switch Name...................... hps_wireless_ctr_green
Secondary Cisco Switch IP Address................ 172.21.1.19
1 ACCEPTED SOLUTION
Hall of Fame Super Silver
No, only the primary WLC you set in the HA
You just need to make sure the mobility is up, which it is and that AP Fallback is enabled on both WLC
That is correct
You can change the primary WLC to point to the other (secondary) WLC.
Here is a good doc.
http://www.cisco.com/en/US/docs/solutions/Enterprise/Mobility/emob41dg/ch2_Arch.html
-Scott
That is correct
Here is a good doc.
-Scott
Scott,
Thank you for the quick, correct response.  I changed the primary WLC on the HA tab of one of the APs and it registered with the secondary almost immediately.  Thanks also for the link to the doc.
mb
No problem... at least you know it works:)
-Scott
3057
