Monitor WLC AP connection
hi.
i want to be alerted if my WLC Looses connection with a AP.
can this be done with SNMP ?
Bronze
You can setup snmp traps to
You can setup snmp traps to alert you to these and many other types of events. In the web interface click on Management  then SNMP then set some trap recievers and then in trap controls you can define what you want traps sent about.
Alteratively you can configure syslog in Management -> Logs
hi thank you for taking your
hi
thank you for taking your time to comment on this.
i have already tried to use SNMP traps, but it does not register when i unplug one of my AP.
syslog is not an option for me :-(
i have upload my current SNMP trap setting on the AP fane. i have disablet all other options
as i do not want to get spammet with traps, i only want AP disconnections.
Hall of Fame Super Silver
I see traps being sent to a
I see traps being sent to a trap receiver when I unplug an access point.  You should see the trap if you run a show traplog on the cli of the WLC also.  If you see that and your monitor tool isn't seeing that trap, then sniff the traffic on the WLC ports and see if you can see the WLC sending that info.  I'm currently testing on v8.0 of the code, but depending on the code you are running, you might be hitting a bug.
Scott
-Scott
i am currently on latest
i am currently on latest release 8.0.100.0.
can you copy paste, your working SNMP CONFIG ?
I have the same AP traps
I have the same AP traps defined as you. What I did was download this free SNMP Trap Reciever to see if traps get sent to that and see the specific OID.  Resetting the AP and unplugging the AP did send an snmp trap to the trap reciever and also show traplog showed the AP dissassociation and re association.
http://www.trapreceiver.com/
Scott
-Scott
Bronze
In addition to martinwisely2,
In addition to martinwisely2, please refer the following links.
http://www.cisco.com/c/en/us/td/docs/wireless/controller/7-2/configuration/guide/cg/cg_troubleshooting.html#wp1161855
http://www.cisco.com/c/en/us/td/docs/wireless/controller/7-2/configuration/guide/cg/cg_troubleshooting.html#wp1064731
Hope that helps.
464
