Move base-ap license to another WLC?
I would like to move the base license from a Cisco air-ct5508-50-k9 to a new air-ct5508-12-k9.
And then move the air-ct5508-12-k9 to the air-ct5508-50-k9. Baically swap them around.
The reason I need to do this is that it will be very hard to move the units physically so just moving the base license would make life much easier.
Does anyone know if this is possible?
Thanks!
  • Getting Started with Wireless
1 ACCEPTED SOLUTION
Ummm no I dont think that is possible actually because its the 'base' licence, i.e the one shipped with the unit.
Perhaps Cisco TAC may be able to assist?
I think this is impossible.
Bronze
Re: Move base-ap license to another WLC?
different devices have different serial numbers, and the license has  that serial number inside it."among other inventory items"
moving the license between WLC's is not possible.
you can open a TAC case stating your problem and someone from the licensing team will help you to sort that out.
This is not possible. for more info you can conatct licensing@cisco.com
Just to follow up. I opened a ticket with the licensing team and they indicated that it was possible.
Sounds strange when Cisco guys here says "impossible", but Cisco licensing team says "possible". Please let us know if it works!
I had a feeling that it was 'possible' if you contacted TAC but I knew you were not able to do it yourself due to licencing with serial numbers etc.
Hall of Fame Super Silver
That is interesting because I have been told many times from TAC and the BU that a base license can't be moved unless for an RMA in which they would provide a new license and or if you had an adder license which that can be moved.
Thanks, Scott *****Help out other by using the rating system and marking answered questions as "Answered"*****
202
