MSE 3350 msed problem
Hi Folks,
It appears that the msed engine does not want to start may be due to a java issue.
I thought might be worthwhile checking here to see  whether anyone had come across this before.
At this stage RMA seems to be the way forward : -)
cheers,
Janesh
[root@xxxxmse01 ~]# /etc/init.d/msed status
STATUS:java.lang.NullPointerException
    at com.aes.client.AesAbstractClient.handleResponse(AesAbstractClient.java:430)
    at com.aes.client.AesClientAdminImpl.getServerInfo(AesClientAdminImpl.java:730)
    at com.aes.server.cli.CmdGetServerInfo.run(CmdGetServerInfo.java:28)
    at com.aes.server.cli.CmdGetServerInfo.main(CmdGetServerInfo.java:47)
[root@xxxxmse01 ~]# ps
  PID TTY          TIME CMD
3386 pts/0    00:00:00 bash
3759 pts/0    00:00:00 ps
[root@xxxx01 ~]# /etc/init.d/msed start
Starting MSE Platform
  PID TTY          TIME CMD
3800 pts/0    00:00:01 java
3862 pts/0    00:00:00 ps
Re: MSE 3350 msed problem
What version of java are you running?  Do "java -version" and post the results. One thing to note, is the at openjdk has issues with MSE, so download the jre from java.com and update your JRE and see if that resolves the problem.
Hi Nael,
This is what I get.Thanks for your reply.
[root@xxxxmse01 ~]# java-version
-bash: java-version: command not found
[root@xxxxmse01 ~]# java -version
-bash: java: command not found
[root@shocmse01 ~]#
cheers,
janesh
Hi folks,
FYI, it was hardware fault as per TAC and we managed to get a RMA organised.
The new unit works fine without any problem.
cheers,
Janesh
459
