Multicast on hwic-ap
Hey all,
I have been having a heck of a time getting multicast setup on over wifi.  Our office recently got a chromecast for a waiting room and wants to stream netflix to it but the app will not work on our wifi.  Netflix's response is multicast is not enabled.  I have a 2811 with the HWIC-AP card for this office.  I am using a bridge interface to combine a LAN and WLAN interface and here is the config:
dot11 ssid SSID NAME
vlan 50
authentication open
authentication key-management wpa
mbssid guest-mode
wpa-psk ascii <KEY>
interface Dot11Radio0/2/0
no ip address
ip nat inside
ip virtual-reassembly in
encryption vlan 50 mode ciphers aes-ccm tkip
encryption vlan 100 mode ciphers aes-ccm tkip
broadcast-key vlan 50 change 30
broadcast-key vlan 125 change 10
ssid SSID NAME
mbssid
speed basic-48.0 basic-54.0
station-role root
infrastructure-client
interface Dot11Radio0/2/0.50
description ### SSID SSID NAME ###
encapsulation dot1Q 50
ip helper-address 192.168.3.1
no ip proxy-arp
ip nat inside
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface FastEthernet0/1.30
description ### ANDY VLAN ###
encapsulation dot1Q 30
ip nat inside
no ip route-cache
bridge-group 1
interface BVI1
ip address 192.168.3.1 255.255.255.0
ip nat inside
Any assistance at all would be great as I am not well versed in HWIC-AP cards and their wifi abilities.
Everyone's tags (3)
Can you post the configuration of the router as well?  in this scenario, all the multicast config will be in the 'router' config and not the 'AP' portion
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
HTH, Steve ------------------------------------------------------------------------------------------------ Please remember to rate useful posts, and mark questions as answered
Here is the config:
version 15.1
service password-encryption
hostname 2811-CME
boot-start-marker
boot system flash c2800nm-adventerprisek9-mz.151-4.M5.bin
boot system flash c2800nm-adventerprisek9_ivs_li-mz.151-3.T.bin
boot-end-marker
security authentication failure rate 3 log
logging buffered 4096
enable secret 5 $1$Oc9P$NoEqI7bMpCegmiiHHbAgl0
aaa new-model
aaa session-id common
clock timezone CST -6 0
clock summer-time CDT recurring last Sun Mar 2:00 last Sun Oct 2:00
dot11 syslog
dot11 ssid SSIDNAME
vlan 50
authentication open
mbssid guest-mode
wpa-psk ascii 7 06121D204F4558405D4F
dot11 ssid Guest
vlan 125
authentication open
mbssid guest-mode
dot11 ssid PRINTER
vlan 100
authentication open
mbssid guest-mode
wpa-psk ascii 7 011F0B0F4159525D71
ip source-route
ip cef
ip dhcp excluded-address 192.168.4.1
ip dhcp excluded-address 192.168.3.1 192.168.3.99
ip dhcp excluded-address 192.168.6.51 192.168.6.254
ip dhcp excluded-address 192.168.2.33 192.168.2.255
ip dhcp excluded-address 192.168.7.1
ip dhcp excluded-address 192.168.6.1 192.168.6.2
ip dhcp excluded-address 192.168.125.1
ip dhcp excluded-address 192.168.2.20 192.168.2.255
ip dhcp excluded-address 192.168.3.131 192.168.3.254
ip dhcp pool VoIP
   network 192.168.4.0 255.255.255.0
   dns-server 4.2.2.1 4.2.2.2
   option 150 ip 192.168.4.1 1.1.1.1
   default-router 192.168.4.1
   option 42 ip 192.168.3.201
   lease 7
ip dhcp pool LAN-MillerNET
   network 192.168.3.0 255.255.255.0
   default-router 192.168.3.1
   option 150 ip 192.168.3.25
   dns-server 192.168.3.1 4.2.2.1 8.8.8.8
   lease 7
ip dhcp pool LAN-DMZ
   network 192.168.2.0 255.255.255.0
   default-router 192.168.2.1
ip dhcp pool STATIC-PRINTER
   host 192.168.100.2 255.255.255.252
   client-identifier 0100.2000.516e.c9
   default-router 192.168.100.1
   dns-server 192.168.3.20
ip dhcp pool CUCM-VoIP
   network 192.168.6.0 255.255.255.0
   default-router 192.168.6.1
   domain-name millernet.us
   dns-server 192.168.3.20 8.8.8.8 4.2.2.1
   lease 7
ip dhcp pool WLAN-Guest
   network 192.168.125.0 255.255.255.0
   dns-server 208.67.222.222 208.67.220.220
   default-router 192.168.125.1
ip name-server 8.8.8.8
ip name-server 4.2.2.1
ip multicast-routing
no ipv6 cef
vpdn enable
vpdn-group 1
redundancy
ip ssh version 2
bridge irb
interface Loopback0
ip address 1.1.1.1 255.255.255.255
interface FastEthernet0/0
description ### UPLINK TO INET (USES DIALER1) ###
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
duplex auto
speed auto
pppoe enable group global
pppoe-client dial-pool-number 1
no cdp enable
description ### TO 3750 ###
no ip address
ip nat inside
no ip route-cache cef
no ip route-cache
duplex auto
speed auto
interface FastEthernet0/1.20
description ### DMZ ###
encapsulation dot1Q 20
ip address 192.168.2.1 255.255.255.0
ip nat inside
no ip route-cache
description ### LAN VLAN ###
ip nat inside
no ip route-cache
bridge-group 1
interface FastEthernet0/1.40
description ### VoIP VLAN ###
encapsulation dot1Q 40
ip address 192.168.4.1 255.255.255.0
ip nat inside
no ip route-cache
interface FastEthernet0/1.60
description ### CUCM VoIP ###
encapsulation dot1Q 60
ip address 192.168.6.1 255.255.255.0
ip nat inside
no ip route-cache
interface FastEthernet0/1.200
description ### SERVER VLAN ###
encapsulation dot1Q 200
ip address 192.168.200.1 255.255.255.0
ip nat inside
no ip route-cache
interface Serial0/0/0
description ### TO LAB ###
ip address 192.168.50.1 255.255.255.252
ip nat inside
clock rate 8000000
no ip address
ip nat inside
ssid SSIDNAME
ssid Guest
ssid PRINTER
mbssid
channel 2412
station-role root
description ### SSID SSIDNAME ###
no ip proxy-arp
ip nat inside
bridge-group 1
interface Dot11Radio0/2/0.100
description ### SSID PRINTER ###
encapsulation dot1Q 100
ip address 192.168.100.1 255.255.255.252
no ip proxy-arp
ip nat inside
interface Dot11Radio0/2/0.125
description ### SSID Guest ###
bandwidth 524288
encapsulation dot1Q 125
ip address 192.168.125.1 255.255.255.0
no ip proxy-arp
ip nat inside
interface Service-Engine1/0
ip unnumbered FastEthernet0/1.30
interface Virtual-Template1
ip unnumbered BVI1
interface Virtual-Template7
ip unnumbered Dialer1
interface Dialer1
description ### VIRT INT TO INET ###
ip address negotiated
ip flow ingress
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication chap pap callin
ppp chap hostname
ppp chap password 7 101E5C4B5C4F4A1B0D0920
ppp timeout idle 180
interface BVI1
ip nat inside
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip http path flash:/cme/GUI
ip dns server
ip nat inside source list 1 interface Dialer1 overload
ip route 0.0.0.0 0.0.0.0 Dialer1
ip access-list extended Asterisk
permit udp any any range 10000 20000
logging esm config
logging 192.168.3.201
control-plane
bridge 1 protocol ieee
bridge 1 route ip
alias exec s show ip interface brief
scheduler allocate 20000 1000
ntp update-calendar
ntp server 192.168.3.201 prefer
end
Well, let's start with cleaning up the configuration. Bridge-Group 1.   Under the radio you are calling it VLAN 50, and on the wire it's VLAN 30.  This should match, so that you aren't sending multiple tags.
multicast routing is already enabled, so it should work.  But I'm also concerned that you have limited the radio to 48 and 54 Mbps.  I can't find anything on the web, but the Chromecast may want the lower rates endabled.  I know that with certain nintendo devices, if you don't have 1 and 2 supported you will have issues.
So I recommend:
1.) correct the configuration so that brdige-group 1 is just vlan 30
2) enable the lower data rates 1,2, 5.5, 11, 12, 18,24,36.  You may also need to change the 'basic' rate(s) that you have set.  in aIOS basic means the device needs to support this rate to connect.  But it also uses the lower 'basic' rate to send multicast at.
HTH,
Steve
Ok thank you for the help, I will change the VLAN around to simply just 30.  I just changed the data rates to only those two today in an attempt to fix it so they were not working with the lower ones as well.  I may change those as well.
To apply the VLAN change do I need to edit this line as well:
no ip address
ip nat inside
ssid SSIDNAME
ssid Guest
ssid PRINTER
mbssid
channel 2412
station-role root
To just encryption vlan 30 mode ciphers aes-ccm tkip & broadcast-key vlan 30 change 30
I attempted this afterhours and after changing the vlan tag in 4 different locations, 1) dot11 ssid 2) Interface radio 0/2/0 encryption vlan 3) Interface radio 0/2/0 broadcast key 4) interface Dot11Radio0/2/0.50 encapculation.
After doing this, I could not connect phones or laptops.  I cannot figure out where the misconfiguration is either.  Any assistnance would be great.
Yes, and change the VLAN under the SSID:
dot11 ssid SSIDNAME
vlan 30
authentication open
mbssid guest-mode
Dot11Radio0.30
encapsulation dot1q 30 native
bridge-group 1
and the
if those don't work, please post the config
HTH,
Steve
This is the changes I made, but since then I reloaded the router and reverted it.
version 15.1
hostname 2811-CME
boot-start-marker
boot-end-marker
aaa new-model
dot11 syslog
dot11 ssid SSIDNAME
vlan 30
authentication open
mbssid guest-mode
dot11 ssid Guest
vlan 125
authentication open
mbssid guest-mode
dot11 ssid PRINTER
vlan 100
authentication open
mbssid guest-mode
ip source-route
ip cef
ip dhcp pool VoIP
  lease 7
ip dhcp pool LAN
   lease 7
   lease 7
vpdn enable
vpdn-group 1
voice-card 0
license udi pid CISCO2811 sn FTX1115A1GG
redundancy
ip ssh version 2
bridge irb
interface Loopback0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
duplex auto
speed auto
no cdp enable
no ip address
ip nat inside
no ip route-cache
duplex auto
speed auto
ip nat inside
no ip route-cache
ip nat inside
no ip route-cache
bridge-group 1
ip nat inside
no ip route-cache
ip nat inside
no ip route-cache
ip nat inside
no ip route-cache
ip nat inside
clock rate 8000000
no ip address
ip nat inside
ssid SSIDNAME
ssid Guest
ssid PRINTER
mbssid
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
station-role root
no ip proxy-arp
ip nat inside
bridge-group 1
no ip proxy-arp
ip nat inside
bandwidth 524288
no ip proxy-arp
ip nat inside
ip unnumbered BVI1
interface Dialer1
ip flow ingress
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp chap hostname <>
ppp chap password 7 <>
interface BVI1
ip nat inside
conf t
no interface Dot11Radio0/2/0.50
interface Dot11Radio0/2/0.30
bridge-group 1
exit
int f0/1.30
encapuslation dot1q 30
bridge-group 1
exit
Int dot11radio0/2/0
that should work.
But to be safe, save the current running config
copy running-config backup-config.
make the changes then do a copy run start then reload
if your clients can't connect, then you can load the backup-config to the running to revert
HTH,
Steve
I have applied the changes and I will check with clients in that building immediately, but some of the lines of the config did not work.
These did not work for the fa0/1.30
These are the only options:
  input-address-list         Filter packets by source address
  input-lat-service-deny     Deny input LAT service advertisements matching a group list
  input-lat-service-permit   Permit input LAT service advertisements matching a group list
  input-lsap-list            Filter incoming IEEE 802.3 encapsulated packets
  input-pattern-list         Filter input with a pattern list
  input-type-list            Filter incoming Ethernet packets by type code
  output-address-list        Filter packets by destination address
  output-lat-service-deny    Deny output LAT service advertisements matching a group list
  output-lat-service-permit  Permit output LAT service advertisements matching a group list
  output-lsap-list           Filter outgoing IEEE 802.3 encapsulated packets
  output-pattern-list        Filter output with a pattern list
  output-type-list           Filter outgoing Ethernet packets by type code
  path-cost                  Set interface path cost
  priority                   Set interface priority
  spanning-disabled          Disable spanning tree on a bridge group
  subscriber-loop-control    Configure subscriber loop control
I checked and no one is able to connect to the wifi with any deivce.  I reverted the config but I saved the config and here it is:
version 15.1
hostname 2811-CME
boot-start-marker
boot-end-marker
aaa new-model
dot11 syslog
dot11 ssid SSIDNAME
vlan 30
authentication open
mbssid guest-mode
dot11 ssid Guest
vlan 125
authentication open
mbssid guest-mode
dot11 ssid PRINTER
vlan 100
authentication open
mbssid guest-mode
ip source-route
ip cef
ip dhcp pool VoIP
   lease 7
ip dhcp pool LAN
   lease 7
   lease 7
no ipv6 cef
vpdn enable
vpdn-group 1
bridge irb
interface Loopback0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
duplex auto
speed auto
no cdp enable
no ip address
ip nat inside
no ip route-cache
duplex auto
speed auto
ip nat inside
no ip route-cache
ip nat inside
no ip route-cache
bridge-group 1
ip nat inside
no ip route-cache
ip nat inside
no ip route-cache
ip nat inside
no ip route-cache
ip nat inside
clock rate 8000000
no ip address
ip nat inside
ssid SSIDNAME
ssid Guest
ssid PRINTER
mbssid
station-role root
bridge-group 1
no ip proxy-arp
ip nat inside
bandwidth 524288
no ip proxy-arp
ip nat inside
ip unnumbered BVI1
interface Dialer1
ip flow ingress
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
interface BVI1
ip nat inside
are your clients configured for WPA2 or WPA?
your vlan 50 encryption is set to aes-ccm tkip
so you may need to go with
HTH,
Steve
I made those changes and clients can connect but the netflix still fails.  I am running out of ideas to be honest.
Has anyone else seen this? I have still not found a solution.
514
