Could be a whole host of things... Easiest option is to post the switchport config from the switch, and the AP config.
Failing that, check that...
VLAN tags & encapsulation types are correct.
Routing is setup correctly
No ACLs / Firewalls
Bridge Groups setup correctly (Native VLAN is normally reserved for BVI 1, and not mapped to an SSID)
