Multiple WAPs without a controller?
Hi.
I have a question that I can't seem to find the answer to.  I wantmy 2 small office 1131AP's to serve the same SSID without a controller.
I know that without a controller I lose smart handoffs and automatic speed and channel selection, not sure what all else.  But this is the hardware I have to work with.
Will the 2 AP's SSID broadcasts step over each other?
Does anyone have any config samples of this setup for me to review?
I have them setup right now.  One is on channel 4 and the other is on channel 10.  This appears to be auto selected, as I did not specify them.
So what is the best way to set this up, to enable seamless connectivity as a user roams from the range of one AP to the other?
AP-1#sh run
Building configuration...
Current configuration : 4803 bytes
version 12.4
no service pad
service password-encryption
hostname AP-1
logging buffered 128000 debugging
logging rate-limit console 9
enable secret <snip>
aaa new-model
aaa group server radius rad_eap
aaa group server radius rad_mac
aaa group server radius rad_acct
aaa group server radius rad_admin
aaa group server tacacs+ tac_admin
aaa group server radius rad_pmip
aaa group server radius dummy
aaa authentication login eap_methods group rad_eap
aaa authentication login mac_methods local
aaa authorization exec default local
aaa accounting network acct_methods start-stop group rad_acct
aaa session-id common
clock timezone PST -8
clock summer-time PDT recurring
clock save interval 24
ip domain name <snip>
ip name-server <snip>
dot11 syslog
dot11 vlan-name Corp vlan 192
dot11 ssid MY-SSID
   vlan 192
   max-associations 50
   authentication open
   authentication key-management wpa version 2
   infrastructure-ssid
   wpa-psk ascii <snip>
   information-element ssidl
dot11 network-map
power inline negotiation injector e05f.xxxx.6936
power inline negotiation prestandard source
crypto pki trustpoint TP-self-signed-xxxx
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-xxxx
revocation-check none
rsakeypair TP-self-signed-xxxx
crypto pki certificate chain TP-self-signed-xxxx
certificate self-signed 01
<snip>
  quit
username Cisco privilege 15 password<snip>
username xxx privilege 15 password<snip>
ip ssh version 2
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption vlan 192 mode ciphers tkip
ssid MY-SSID
station-role root
no cdp enable
interface Dot11Radio0.192
encapsulation dot1Q 192 native
no ip route-cache
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface Dot11Radio1
no ip address
no ip route-cache
dfs band 3 block
channel dfs
station-role root
no cdp enable
interface Dot11Radio1.192
no ip route-cache
bridge-group 1
interface FastEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
interface FastEthernet0.192
no ip route-cache
bridge-group 1
interface BVI1
ip address 192.168.0.3 255.255.255.0
no ip route-cache
ip default-gateway 192.168.0.1
ip http server
ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
ip radius source-interface BVI1
radius-server attribute 32 include-in-access-req format %h
radius-server vsa send accounting
bridge 1 route ip
line con 0
line vty 0 4
sntp server <snip>
sntp broadcast client
end
2 ACCEPTED SOLUTIONS
Setting up both APs with the same SSID/security/vlan settings should be enough to provide for seamless roaming provided you have sufficient over lap between the APs
PIggy backing Sudha/Ambrosia,
You should also set your AP to use channel 1, 6 or 11 (2412,2437,2462).
Steve
HTH, Steve ------------------------------------------------------------------------------------------------ Please remember to rate useful posts, and mark questions as answered
Steve
Thanks for the validation.  It is working well now.
965
