N with controller 4402 with AP 1250
Hi, I tried to use AP 1250 with a 4402 controler for use the N band. All the AP work fine with G but not with N. Somebody have this problem? Where I can find the doc for configure this.
Simon
Re: N with controller 4402 with AP 1250
Are you using WPA+TKIP or WEP?
Which client card are you using?
Check this link from intel. The draft at the moment forbids using highspeedthroughput with WEP and TKIP as the unicast cipher key method.
http://www.intel.com/support/wireless/wlan/4965agn/sb/cs-025643.htm
You should switch to WPA2, then N rates should be enabled.
Gustavo
Configuration of Layer 2 security I use WPA+WPA2. Check the screenshot.
Simon
Hii
dot11n rates will be availabe only with WPA2+AES security combination.
ALso make sur you have enabled the 11n support on the controller.Check the same under wireless->802.11b/g->network
Vinay
Hall of Fame Super Silver
Also configure the ap to use 40mhz channel width.... but remove the wpa policy.
-Scott
Hii Fella5/Oscar
40 Mhz operation is not recomended for 2.4 GHz freq. , you can try that on 5Ghz.
But I guess controller still supports for both :)
Vinay
Sorry... didn't see that they wanted to run it on the 2.4ghz.
-Scott
Make sure that WMM Policy (under QOS) is set to allowed. WMM is mandatory for operation of "N" rates. Without it, you'll only get G rates in 2.4 and A rates in 5.
Thanks, I'll try all your answer.
Simon
Someone have a web site or a file with the requirement for use N band with my hardware?
Simon
Hii simon ,
seems like ur problem is still not solved, can u pls attach the omnipeek capture for Beacons, probes and assoc handshake for ur client.
That will help us analyse where the problem is.
Also login to ur 1250 AP , if MCS rates are not allowed due to some config issue AP will generate message.
vinay
196
