Need help getting a Cisco 1200 Series AP 12.02T1 up and running...
Hello everyone,
We dusted out an old AP1200 that we want to use as an access point in our office.  I can log into it via the webconsole but I need help setting up WEP.  I dont understand that cisco lingo.
so far I go to Setup - Security and then I am presented with the option of:
Radio Data Encryption (WEP) for AP Radio: Internal
Radio Data Encryption (WEP) for AP Radio: Module
Either of the two options take me a window with the following:
Accept Authentication Type of open, shared  or network-eap and also a required EAP with open and shared as checkbox options.
Then it has 4 wep key options with encryption keys.  I enter my encryption key such as companynameplusextranumbers with a key size of either not set, 40 or 128 bit and then I get the following error:
An error "Invalid Value" occurred for the parameter "awcDot11WEPDefaultKeyValue" while applying selected settings to the page. Please click here to correct the problem and try again.
bottom line is that I have no clue how to work this thing....is it even worth my time or should we get something else....even a linksys from a big box store should be suffice (small environment)
Can someone help me with this or guide me to some sort of tutorial?
Thanks!
Everyone's tags (4)
1 REPLY
Hall of Fame Super Silver
557
