Community Member
Need help on register AP to WLC
I have an LAP on the same subnet with the WLC. I can ping the AP from the controller and everywhere on the same subnet. But I can't see it join to the WLC. I checked the command on WLC:
(Cisco Controller) > show ap join stats summary all
but the LAP does not show on the list. I ran this with MAC address of the AP
(Cisco Controller) > show ap join stats summary MACADDRESS
but I can't find the AP either.
the AP is running C1310-k9w7-mx.123-8.JEA3
On the AP, I ran set command, it shows:
ap: set IP_ADDR ....etc correctly with my address to setup
Some documentation shows the command ap1310>capwap ap ip address So when should I start  using these command?
How do i correct this problem so my ap can join?
I am really appreciated for your help
Hall of Fame Super Silver
You need to be running a lightweight code on that 1310 not an IOS.
To piggy back on Scotts comment.
The 1310 can be ran as autonmous OR lightweight.
* Note -- 1310 will not working on 7.2 WLC code, shold you use these in a lightweight environment.
