Need help to configure AP 1142 in Autonomous mode
Hi All,
Need some help. I am trying to configure Cisco Aironet 1142 in Autonomous mode, this AP was previously connected to WLC and from previous post I found that we need to delete and reload the AP
private-multiple-fs, c1140-k9w8-mx.124-21a.JHA
Now when I am trying to configure IP address for AP it is giving error:
AP1142#lwapp ap ip address 10.61.1.151 255.255.255.0
ERROR!!! Command is disabled.
AP1142#
Current flash contents:
AP1142#dir
Directory of flash:/
    2  -rwx       10264   Mar 1 2002 01:25:57 +00:00  private-multiple-fs
    3  -rwx       90396   Mar 1 2002 01:18:04 +00:00  event.log
    5  drwx         128   Mar 1 2002 00:12:24 +00:00  c1140-rcvk9w8-mx
    8  -rwx           0   Mar 1 2002 01:26:06 +00:00  config.txt
    9  -rwx         337   Mar 1 2002 01:18:04 +00:00  env_vars
32385024 bytes total (30019584 bytes free)
AP1142#
Please let me know whatelse is needed to get the AP configured in Automous mode.
Thanks in advance
1 ACCEPTED SOLUTION
Re: Need help to configure AP 1422 in Autonomous mode
The image that is on the device is LWAPP one, not the autonomous.. if you want to use the AP in autonoous mode then the image should be W7.. that is..
c1140-k9w7-mx.124-21a.JHA not c1140-k9w8-mx.124-21a.JHA.
I request you to do download any image from the below link and perform the conversion from LWAPP image to autonomous..
http://tools.cisco.com/support/downloads/go/PlatformList.x?sftType=IOS+Software&mdfid=282439881&treeName=Wireless&mdfLevel=Model&url=null&modelName=Cisco+Aironet+1140+Access+Point&isPlatform=N&treeMdfId=278875243&modifmdfid=null&imname=&hybrid=Y&imst...
the methos to convert is..
download TFTPd32 from google and install it on ur PC.. point the image that you have downloaded in the TFTP server..
connect a ethernet cable between ur laptop and AP.. both should be in the same subnet.. and connect a console cable and get the hyperterminal console access and issue the command..
AP>en
AP#debug lwapp console cli or debug capwap console cli
AP#config t
AP(confg)int fa 0
AP(confg-if)ip addr (same subnet as that of the laptop)
AP(confg-if)end
AP#archieve download-sw /force-reload /overwrite tftp:///
This will resolve the issue..
Surendra
AP>en
AP#config t
AP(confg)int fa 0
AP(confg-if)end
Surendra
Re: Need help to configure AP 1142 in Autonomous mode
Hi Surendra,
Thanks a lot for your quick reply, let me dowload the software. Will keep posted incase of any issues still..
Thanks again :-)
Re: Need help to configure AP 1242 in Autonomous mode
Hi Surendra,
Is there anyway to convert Cisco1240AG to IOS mode using CLI instead of TFTP.
Hall of Fame Super Gold
I know of the TFTP server, is it possible to downgrade with CLI commands just like 1140 AP's.
Thank you,
Hi Pramod,
yes it is possible and its the same method.. instead of selecting the 1140 image.. provide the 1242 AP image.
lemme know how this works out for you!!
Surendra
Sorry for the late response.. missed this post's message
Could you please let me know the commands, the one I used for 1140 aren't working here
what command did we try??
Surendra
AP>en
AP#config t
AP(confg)int fa 0
AP(confg-if)end
Its the same..
Here are the command available
APf866.f2a8.a342#debug lwapp ?
  client          LWAPP Client Debug Options
  iapp-data-echo  LWAPP IAPP data plane echo
APf866.f2a8.a342#debug lwapp cli ?
  cc             Call Control related debugs
  config         LWAPP Client Config Messages
  error          LWAPP Client Error Messages
  event          LWAPP Client Event Debugging
  fmc-metrics    LWAPP Client FMC Metrics
  fwd            LWAPP Client dot11 forwarding
  mgmt           LWAPP Client dot11 mgmt
  packet         LWAPP Client Packet debugging
  reassembly     LWAPP Client Fragment Reassembly
  voice-metrics  LWAPP Client Voice Metrics
APf866.f2a8.a342#debug capwap ?
  client  CAPWAP Client Debug Options
  mcast   CAPWAP MCAST Debug Options
  mfp     CAPWAP MFP Debug Options
APf866.f2a8.a342#debug capwap cli
APf866.f2a8.a342#debug capwap client ?
  config          CAPWAP Client Config Messages
  detail          CAPWAP Client Detail Messages
  error           CAPWAP Client Error Messages
  event           CAPWAP Client Event Messages
  fwd             CAPWAP Client dot11 forwarding
  hexdump         CAPWAP Client Hexdump Messages
  info            CAPWAP Client Info Messages
  lsc             CAPWAP Client LSC Events
  mgmt            CAPWAP Client dot11 mgmt
  packet          CAPWAP Client Packets
  payload         CAPWAP Client Payload Messages
  reassembly      CAPWAP Client Fragment Reassembly
  tcp-mss-adjust  CAPWAP client MSS adjust
  tcp-mss-print   CAPWAP Client MSS print
its DEBUG LWAPP CONSOLE CLI or DEBUG CAPWAP CONSOLE CLI
This is kind of hidden command.. lemme know how this works out for you!!
Surendra
You are awsome!!!..
DEBUG CAPWAP CONSOLE CLI is hidden command.
Just converted to Autonoumous mode
Thanks again for your help!!
it was my pleasure assisting you!!! its great to hear that the issue is resolved..
have a great day!!
Surendra
Hi Surendra BG
Thanks for the post . I did come across a situation to change 1142N-A-K9 from light weight to autonomous mode.
Here the process was very simple. But I have to break my head for finding the correct method. I have pointed the image in tftpd32 as per your instructions and also connected my laptop using straight cable to AP.also assigned the ip 10.0.0.2 to my laptop.
i was trying to bring the AP to blink red. using the MODE button. During this process of bringing to blinkng red. AP itself started accessing the tftp service  on its own for the file name "c1140-k9w7-tar.default"  Since the file name of my image was something like "c1140-k9w7-tar.124-25d.JA.tar" , the AP was not getting the file and after few min the AP goes to mode "ap: " (recovery mode) ,
from here you cannot convert the image. Then i figured it out using wireshark that the AP itself by default gets the ip 10.0.0.1 and access the tftp service with the file name "c1140-k9w7-tar.default" . I changed the image of the file name to this one and pointed my tftpd32 to this image. At the next attempt the AP got loaded to this image and it is now in autonomous mode. i think the commands are not necessary now as the AP have converted the image the K9w7..Thanks for the link . I thought i would share this info as this would help someone like me who is spending more time to do this..
Sundar
4225
