Need Help with Installing AP 1250
I am installing AP 1250 with wireless client authenticating to radius server running on MS ISA server.   The users are supposed to be authenticating with AD.  So far I have been running into problems and unable to get any user connected via Wireless LAN.
I would like your feedback if the configuration is good on the AP. Do I need tweak it to work?   The plan is to install one and then install the rest of the 3 more APs in the infrastructure.   I would like to get the one up and running first.
I would like any suggestion to enhance my configuration and design guidance.   Also need help for ISA configuration.
Config from AP
    hostname cisco1-ap
    aaa new-model
    aaa group server radius rad_eap
     server 10.1.2.25 auth-port 1812 acct-port 1813
    aaa group server radius rad_acct
    aaa group server radius rad_admin
    aaa group server tacacs+ tac_admin
    aaa group server radius rad_pmip
    aaa group server radius dummy
    aaa group server radius rad_mac
    aaa authentication login default local
    aaa authentication login eap_methods group rad_eap
    aaa authentication login mac_methods local
    aaa authorization exec default local
    aaa accounting network acct_methods start-stop group rad_acct
    dot11 ssid ABCD123
     authentication open eap eap_methods
     authentication network-eap eap_methods
     authentication key-management wpa
     guest-mode
     infrastructure-ssid optional
    power inline negotiation injector installed
    bridge irb
    interface Dot11Radio0
     no ip address
     no ip route-cache
     encryption mode ciphers tkip
     ssid ABCD123
     station-role root
     rts threshold 2312
     no dot11 extension aironet
     bridge-group 1
    bridge-group 1 subscriber-loop-control
     bridge-group 1 block-unknown-source
     no bridge-group 1 source-learning
     no bridge-group 1 unicast-flooding
     bridge-group 1 spanning-disabled
    interface Dot11Radio1
    shutdown
    interface FastEthernet0
     no ip address
     no ip route-cache
     speed 100
     full-duplex
     bridge-group 1
    ip http server
    ip http authentication aaa
    no ip http secure-server
    ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
    ip radius source-interface BVI1
    radius-server attribute 32 include-in-access-req format %h
    radius-server host 10.1.2.25 auth-port 1812 acct-port 1813 key 0 XXX-XXX-XXX-X
    radius-server deadtime 5
    radius-server vsa send accounting
    radius-server vsa send authentication
    bridge 1 route ip
    line con 0
    line vty 0 4
1 REPLY
Re: Need Help with Installing AP 1250
It is IAS and not ISA server.  I apologies for the confusion it might have caused you.
805
