Need help with IOS commands to see wireless printer
Seems that I'm not asking the question correctly, or providing the right information.
The problem:
I've purchased a wireless printer, (an HP 6500a) and I can not see / ping / use the printer on the wireless network.
Environment:
Cisco 891 ISR in standalone. Single office - Home-office environment. Nothing spectacular. WLAN connected and operational to the internet.
The printer is configured to use a static IP of 10.0.0.3 and reports that it is connected to the AP. However, when I ping FROM the command line at the AP, I DO NOT see the printer. (I did previously, but we lost power last night due to a storm and I'm still trying to reconfigure it...) DHCP is configured on the router to exclude the range 10.0.0.1 through 10.0.0.99
How do I configure the wireless router to allow any connected client to share files / printers etc? Seems that the Cisco router has this shut off
by default and I've found nothing in the user manual or by asking for help on here how to reverse this so that I can share printers / files on the LAN.
Please, I'm not stupid, but I'm only casually familiar with IOS and Cisco's networking terms.
Thanks in advance,
-Mike
=============== Begin Wiresless AP config (running-config) ==============
Current configuration : 3122 bytes
version 12.4
no service pad
hostname (Remnoved)
enable secret 5 (Removed)
no aaa new-model
dot11 syslog
dot11 ssid (Removed)
   vlan 1
   authentication open
   authentication key-management wpa
   mbssid guest-mode
   wpa-psk ascii 0 (Removed)
username (removed)
username (Removed)
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption vlan 1 mode ciphers tkip
broadcast-key vlan 1 change 30
ssid (Removed)
antenna gain 0
station-role root
interface Dot11Radio0.1
encapsulation dot1Q 1 native
no ip route-cache
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface Dot11Radio1
no ip address
no ip route-cache
ssid (Removed)
antenna gain 0
dfs band 3 block
channel dfs
station-role root
interface Dot11Radio1.1
no ip route-cache
bridge-group 1
interface GigabitEthernet0
description the embedded AP GigabitEthernet 0 is an internal interface connecting AP with the host router
no ip address
no ip route-cache
interface GigabitEthernet0.1
no ip route-cache
bridge-group 1
interface BVI1
ip address dhcp client-id GigabitEthernet0
no ip route-cache
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
access-list 110 permit icmp any any echo
access-list 110 permit icmp any any echo-reply
access-list 110 permit icmp any any source-quench
access-list 110 permit icmp any any packet-too-big
access-list 110 permit icmp any any time-exceeded
bridge 1 route ip
banner login ^CC
% Password change notice.
Default username/password setup on AP is cisco/cisco with privilege level 15.
It is strongly suggested that you create a new username with privilege level
15 using the following command for console security.
username <myuser> privilege 15 secret 0 <mypassword>
no username cisco
Replace <myuser> and <mypassword> with the username and password you want to
use. After you change your username/password you can turn off this message
by configuring  "no banner login" and "no banner exec" in privileged mode.
^C
line con 0
privilege level 15
login local
no activation-character
line vty 0 4
login local
cns dhcp
end
Hall of Fame Super Silver
Re: Need help with IOS commands to see wireless printer
Can you tell us what ap you have. Can you post your config of the router and ap?
Scott Fella
Sent from my iPhone
-Scott
Sorry... My phone didn't show the whole thread do I didn't see your ap config. Is your wireless users working okay except they can't file share?
-Scott
Wireless clients can get on w/o issue. Nobody can ping anyone else or see them.
No file sharing, no printer.
Tried using the web-based config which works for some items, but wont access the advanced config.
I'm on my way into town, so can't post the router config, but it is posted in my earlier question
of last week. I can login later if you otherwise need it here.
-Mike
you're not blocking anything so the clients should be able to see each other.
show dot11 associations
will show you the clients that are connected to the AP
Steve
HTH, Steve ------------------------------------------------------------------------------------------------ Please remember to rate useful posts, and mark questions as answered
381
