Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
Need help with WRVS4400N with SR600ex (Amped Wireless)
Hello, I don't have too much knowledge in networking, I set up the WRVS4400N, without any issues, when setting up the SR600ex to be used as a repeater I had them directly next to each other, no connection issues, I contiued to setup the unit with the same SSID and password as the WRVS4400N, the issue I am having is as soon as I set up the SR600ex where I want it to be wich is less than 100 ft. away it does not pick up the WRVS, another question I have is, if I do get it to work correctly, will my wireless devices automatically switch to the next device when losing range from the one connected before. Should I scrap the Idea and take back both products. What do you "Pros" think?
662
