Need to Connect Toshiba 2100Satellite Pro to AP1200????
I am trying to connect the Toshiba laptop with built in WI-FI solution with AP1200. I have configure the WLAN card but it doed not connect with AP1200.
This is the first time, these laptops comes in with WI-FI...
Can you please advice me which is the best way to connect or AP1200 does not support the built in cards in laptops yet.
1 REPLY
Re: Need to Connect Toshiba 2100Satellite Pro to AP1200????
please make sure that built in wireless card in a Toshiba laptop is wi-fi cerified , If it is wi-fi certified than it should connect to the Ap1200 .
You need to modify the config on Ap1200
a) Let's factory default the config on Ap1200 .
Go to setup --> express setup
Checl on non-aironet 802.11 option
b) Go to Radio -> Advance page
uncheck Aironet extention .
( You need to disable aironet extention )
on same page , check preamble . It can be short or long . It needs to match
with what is on AP . try both
Modulation -> default is standad . if this does not work try other .
Remember try without encryption first .
Nilesh
173
