01-23-2014 11:09 AM - edited 07-05-2021 12:02 AM
Hi all,
We have several AP units with this module but one of them needs to be rebooted daily in order for users to connect to network. We did replace the unit but new one is still acting the same. Please advise. Thank you very much for all advises.
Solved! Go to Solution.
01-25-2014 03:54 AM
Hi, your image is very recent. Probably your issue is caused by a bug. I suggest you to contact the TAC.
Probably your 1242 is a Lightweight model and it is made to operate with the Wireless Lan Controller type Unified deployment. You can convert it to Autonomous or Standalone mode to have a CLI IOS.
Regards.
01-23-2014 12:23 PM
What is the IOS version of units? Is the same for new and replaced device?
Try updating the firmware. Many bugs are fixed in latest IOS.
As workaround you can configure a daily reboot using kron CLI:
kron occurrence EVERY_DAY at 0:00 recurring
policy-list RELOAD
kron policy-list RELOAD
cli write
cli reload
Regards.
01-23-2014 01:14 PM
Hi Daniele,
Thanks for jumping in to help. My version is : c1240-k9w8.124-25e.JAM2. If need to update firmware, which image should I download ?
About the work around, I cannot find the parameter "kron occurence ...". As matter of fact, I cannot issue command "conf t" so please educate me a bit more. Thanks again.
01-25-2014 03:54 AM
Regards.
01-29-2014 08:15 AM
Thanks, Daniele.
