NetFlow and WCL5508
What is needed to caputre NetFlow data from a WLC5508?
Is the 5508 NetFlow capable like routers?
Thanks - Phil
Everyone's tags (1)
1 ACCEPTED SOLUTION
VIP Purple
It is not standard Netflow,
It is not standard Netflow, so you need to have customized flow collector that will understand WLC netflow format.
Cisco Prime Assurance, Scrutinizer work as flow collector.(may be few other products too). Below will help you get an idea based on what I have tested sometime back.
http://mrncciew.com/2013/02/13/who-really-support-wlc-netflow/
http://mrncciew.com/2013/02/12/configuring-netflow-on-wlc-7-4/
Rasika
**** Pls rate all useful responses ****
VIP Purple
Rasika
Rasika,Yes, that is exactly
Rasika,
Yes, that is exactly what I'm looking for!  This is the sort of in-depth answer I was hoping for.
Now on to the implementation phase
Phil
VIP Purple
No worries Phil. Glad that
No worries Phil. Glad that helps you...
You can mark this thread as "answered" if you get what you looking for
Rasika
87
