Community Member
New 3825 and NM-AIR-WLC6-K9 WLAN Controller Network Module
I can't get this to work for the life of me.  I also don't have GUI access which is part of the problem I'm betting.  I can't ping from the WLAN controller past the 3825 it's plugged into.  I'm sure it's something easy i'm missing, but i've been looking at it too long.  can someone help please?  The Aironet 1510 AIR-LAP1510KITP-A keeps renewing different IP addresses from the router as well. like every 5 minutes.  thanks. Router config:
no aaa new-model
dot11 syslog
ip source-route
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.100.1 192.168.100.100
ip dhcp excluded-address 192.168.100.151 192.168.100.255
ip dhcp excluded-address 192.168.15.1 192.168.15.100
ip dhcp excluded-address 192.168.16.1 192.168.16.100
ip dhcp excluded-address 192.168.98.1 192.168.98.100
ip dhcp pool FPLOCAL
   network 192.168.100.0 255.255.255.0
   dns-server 172.10.10.1
   default-router 192.168.100.1
ip dhcp pool vlan-15
   network 192.168.15.0 255.255.255.0
   default-router 192.168.15.1
ip dhcp pool vlan-16
   network 192.168.16.0 255.255.255.0
   default-router 192.168.16.1
ip dhcp pool lwapp-ap
   network 192.168.98.0 255.255.255.0
   default-router 192.168.98.1
   option 43 ascii "192.168.99.24"
   option 60 ascii "Cisco AP.LAP1510"
ip domain name covcom.com
ip ddns update method troy
password encryption aes
crypto pki trustpoint TP-self-signed-*
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-*
revocation-check none
rsakeypair TP-self-signed-*
crypto pki trustpoint example
enrollment terminal pem
revocation-check crl
crypto pki certificate chain TP-self-signed-*
certificate self-signed 01
crypto pki certificate chain example
license udi pid CISCO3825 sn FTX1338A0MX
archive
log config
  hidekeys
ip ssh maxstartups 4
ip ssh time-out 60
bridge irb
interface GigabitEthernet0/0
description $ETH-LAN$$ETH-SW-LAUNCH$$INTF-INFO-GE 0/0$
ip address 172.10.10.4 255.255.255.0
ip access-group 100 in
ip nat outside
ip virtual-reassembly
duplex auto
speed auto
media-type rj45
interface GigabitEthernet0/1
description Trunk Port to Cisco WLC
no ip address
duplex auto
speed auto
media-type rj45
interface FastEthernet0/1/0
interface FastEthernet0/1/1
interface FastEthernet0/1/2
interface FastEthernet0/1/3
interface FastEthernet0/1/4
interface FastEthernet0/1/5
interface FastEthernet0/1/6
interface FastEthernet0/1/7
interface FastEthernet0/1/8
description Lightweight Access Point
switchport access vlan 100
interface Integrated-Service-Engine1/0
ip address 192.168.99.254 255.255.255.0
no keepalive
interface Integrated-Service-Engine1/0.15
encapsulation dot1Q 15
bridge-group 15
interface Integrated-Service-Engine1/0.16
encapsulation dot1Q 16
bridge-group 16
interface Vlan1
ip address 192.168.100.1 255.255.255.0
ip nat inside
load-interval 30
interface Vlan100
ip address 192.168.98.1 255.255.255.0
load-interval 30
interface BVI15
ip address 192.168.15.1 255.255.255.0
interface BVI16
ip address 192.168.16.1 255.255.255.0
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source static tcp 192.168.100.9 2321 interface GigabitEthernet0/0 2321
ip nat inside source static tcp 192.168.100.10 2322 interface GigabitEthernet0/0 2322
ip nat inside source route-map DONTNAT interface GigabitEthernet0/0 overload
ip nat inside source static 192.168.99.24 172.10.10.5 extendable
ip nat inside source static 192.168.100.6 172.10.10.6 extendable
ip nat inside source static 192.168.100.7 172.10.10.7 extendable
ip nat inside source static 192.168.100.8 172.10.10.8 extendable
ip route 0.0.0.0 0.0.0.0 172.10.10.1
ip access-list extended pat
deny   ip 192.168.100.0 0.0.0.255 192.168.101.0 0.0.0.255
permit ip 192.168.100.0 0.0.0.255 any
access-list 23 permit 192.168.101.0 0.0.0.255
access-list 23 permit 192.168.100.0 0.0.0.255
access-list 24 permit 0.0.0.0
access-list 100 permit ip any any
route-map DONTNAT permit 10
match ip address pat
control-plane
bridge 15 protocol ieee
bridge 15 route ip
bridge 16 protocol ieee
bridge 16 route ip
banner login ^C
^C
line con 0
login local
line aux 0
line 66
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120
line vty 0 4
privilege level 15
login local
transport input all
transport output all
line vty 5 15
privilege level 15
login local
transport input all
scheduler allocate 20000 1000
end
CISCO3825FP#sh ver
Cisco IOS Software, 3800 Software (C3825-IPBASEK9-M), Version 15.1(1)T, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Mon 22-Mar-10 03:30 by prod_rel_team
ROM: System Bootstrap, Version 12.4(13r)T11, RELEASE SOFTWARE (fc1)
CISCO3825FP uptime is 9 weeks, 1 day, 7 hours, 6 minutes
System returned to ROM by reload at 17:14:51 UTC Wed Jun 2 2010
System image file is "flash:c3825-ipbasek9-mz.151-1.T.bin"
Last reload type: Normal Reload
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco 3825 (revision 1.2) with 221184K/40960K bytes of memory.
Processor board ID *
9 FastEthernet interfaces
2 Gigabit Ethernet interfaces
1 terminal line
1 cisco Integrated Service Engine(s)
   Cisco WLAN Controller 5.2.178.0 in slot 1
DRAM configuration is 64 bits wide with parity enabled.
479K bytes of NVRAM.
62720K bytes of ATA System CompactFlash (Read/Write)
License Info:
License UDI:
Device#   PID                   SN
*0        CISCO3825             *
CISCO3825FP#
WLAN Controller config from here:  http://www.cisco.com/en/US/tech/tk722/tk809/technologies_tech_note09186a00807112e2.shtml#c3
Everyone's tags (5)
Hall of Fame Super Gold
Re: New 3825 and NM-AIR-WLC6-K9 WLAN Controller Network Module
Why do you have BVI15 and BVI16???
Community Member
not entirely sure.  i picked it up from that config page for the WLAN controller.  i had it the other way with just vlan's and no bridges, but it still didn't work.
1576
