No console output on 4404
Setting up a 4404 and plugged in to console and I get no output... The status light is solid and then blinks and then goes out - sounds normal. I used a rollover to DB9 connector, tried a couple of different connectors, and even tried a 232 connector with no luck.
First time with a 4404. Is it a brick, or does it take 15 minutes to boot? Checked my serial settings to be sure and all good. Thanks for any help...
1 REPLY
Re: No console output on 4404
Hi Mike,
You want to use a null modem cable ONLY for console. It takes 3 - 4 minutes to load... Try the null modem cable and see if that works for u
__________________________________________________________________________________________ "Satisfaction does not come from knowing the solution, it comes from knowing why." - Rosalind Franklin ___________________________________________________________
251
