Community Member
No IP's with Aironet 1142N connected to ASA 5505
Hi there! I'm probably missing something really simple but I have an Aironet 1142N autonomous AP connected to and receiving PoE from an ASA 5505 w/ Security + license. The AP is configured with two SSID's, and has a management IP set, all utilizing difference VLAN's. My issue is that I cannot get an IP for either VLAN once connected. When tailing my DHCP server logs I see the DHCP discover message hit the server, the server offers an IP, but then nothing. As a test I trunked a switch to the same port on the ASA, plugged my computer into a configured switchport, and was able to get IP's for my VLANs just fine so I'm assuming that I'm missing something on the AP side.
My port configuration on the ASA is as follows:
interface Ethernet0/6
description Wireless-Network-Interface
switchport trunk allowed vlan 100,200,253
switchport trunk native vlan 253
switchport mode trunk
Below is my AP config:
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime
service timestamps log datetime msec localtime
service password-encryption
hostname AP
logging rate-limit console 9
enable secret
no aaa new-model
clock timezone est -5
clock summer-time edt recurring 1 Sun Mar 2:00 1 Sun Nov 2:00
no ip source-route
no ip domain lookup
ip domain name
dot11 mbssid
dot11 syslog
dot11 ssid Guest
   vlan 200
   max-associations 10
   authentication open
   authentication key-management wpa version 2
   mbssid guest-mode
   wpa-psk ascii
dot11 ssid Internal
   vlan 100
   max-associations 7
   authentication open
   mbssid guest-mode
   wpa-psk ascii
username
ip ssh time-out 60
ip ssh authentication-retries 2
ip ssh version 2
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption vlan 100 mode ciphers aes-ccm
encryption vlan 200 mode ciphers aes-ccm
broadcast-key vlan 100 change 500
broadcast-key vlan 200 change 500
ssid Guest
ssid Internal
antenna gain 0
station-role root
interface Dot11Radio0.100
encapsulation dot1Q 100
no ip route-cache
bridge-group 100
bridge-group 100 subscriber-loop-control
bridge-group 100 block-unknown-source
no bridge-group 100 source-learning
no bridge-group 100 unicast-flooding
bridge-group 100 spanning-disabled
interface Dot11Radio0.200
encapsulation dot1Q 200
no ip route-cache
bridge-group 200
bridge-group 200 subscriber-loop-control
bridge-group 200 block-unknown-source
no bridge-group 200 source-learning
no bridge-group 200 unicast-flooding
bridge-group 200 spanning-disabled
interface Dot11Radio0.253
encapsulation dot1Q 253 native
no ip route-cache
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface Dot11Radio1
no ip address
no ip route-cache
ssid Guest
ssid Internal
antenna gain 0
dfs band 3 block
channel dfs
station-role root
bridge-group 1
interface Dot11Radio1.100
no ip route-cache
bridge-group 100
interface Dot11Radio1.200
no ip route-cache
bridge-group 200
interface Dot11Radio1.253
no ip route-cache
bridge-group 1
interface GigabitEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
no keepalive
interface GigabitEthernet0.100
no ip route-cache
bridge-group 100
interface GigabitEthernet0.200
no ip route-cache
bridge-group 200
interface GigabitEthernet0.253
no ip route-cache
no keepalive
bridge-group 1
interface BVI1
ip address 192.168.253.200 255.255.255.0
no ip route-cache
ip default-gateway 192.168.253.1
no ip http server
no ip http secure-server
ip radius source-interface BVI1
bridge 1 route ip
line con 0
line vty 0 4
login local
transport preferred none
transport input ssh
transport output ssh
end
Any help you guys can dish out would be greatly appreciated!!!!!!!!!
THANK YOU!!!!!!!
-Ken
Everyone's tags (2)
Exiting to hear about an AP connected directly to ASA port
Wondering if you have multiple VLAN's enabled on the ASA port for the SSID
NikhiL
Community Member
I do:
Bronze
Re: No IP's with Aironet 1142N connected to ASA 5505
Your AP config looks solid.  Since you are seeing "some" DHCP traffic (Discover, then server Offer), I would suggest a wireshark capture directly on the client as an easy quick test.  I'm curious if the OFFER arrives at the client.  If you don't see the OFFER, then either 1. The offer didn't make it to the AP (tough to "prove" directly connected) 2. The OFFER was not processed correctly by the AP 3. The AP did not transmit, over-the-air, the DHCP OFFER to the client.  It "seems" like the AP isn't receiving or processing the OFFER from the ASA.  It's kind of tough to examine the packets being directly connected.  The debugs are limited on the AP for the "client" traffic.
Wireshark on client
Over the Air Capture if not seeing OFFER at client.
Community Member
Thanks for you reply and yeah, it's completly bizarre!!! I Wiresharked the wireless connection on my client side and the only things I saw was the outgoing Discover broadcast traffic which repeated several times and then finally the 169 address traffic from my client. I'm not seeing anything coming back from the AP at all. I also did dumps off the interfaces on my ASA and I am actually seeing the Offer packets being sent to the correct interface but from there they seem to just vaporize! Just for shiggles, I'm gonna try the same config on another AP just to see what happens. I know it's pretty rare for it to be a device problem but I guess weirder things have happened!!!
Thanks!!!!!
Community Member
So after taking a failing shot in the dark with another AP I decided to rebuild my config line by line. I started by getting it to work using only one SSID over a specific VLAN and management IP, then adding a second VLAN, etc etc. In the end I got it to work with a slightly modified config!!!!! I have attached a copy of my working config for reference or for anyone who may run into an issue like this in the future. Thanks!!!!!!!!!!!!
1904
