No ping possible between AIR-SAP1602I-E-K9 and Cisco 866VAE-K9 router with multiple SSID´s / VLANs
All,
I´m playing with a standalone AIR-SAP1602I-E-K9 and an Cisco 866VAE-K9 router trying to set up a WLAN with 3 SSID´s / VLAN´s. The gig interface of the AP is directly connected to the router´s gig switchport. My plan was to configure the routers switchport as a trunk (nativ vlan 1) with the respective SVI´s. On the AP I confgirued the SSID´s mapped to the corresponding VLAN and configred 3 different subnet´s on the BVI´s. So far so good. After doing this I expected to be able to ping from the SVI´s to the BVI´s and vice versa but I it does not work... to be honest right now i have no idea why. All interfaces Radio/Gig/ BVI´s are up on the AP, all SVI´s on the router are up. Can someone have a look on what i configured? Any hints appreciated. Thank you in advance.
AP´s config --> image is flash:/ap1g2-k9w7-mx.152-2.JB/ap1g2-k9w7-mx.152-2.JB
<snip>
dot11 ssid SSID_1
   vlan 1
   max-associations 5
   authentication open
   authentication key-management wpa version 2
   wpa-psk ascii key_1
dot11 ssid SSID_3
   vlan 3
   max-associations 5
   authentication open
   wpa-psk ascii key_3
dot11 ssid SSID_2
   vlan 2
   max-associations 5
   authentication open
   wpa-psk ascii key_2
interface Dot11Radio0
no ip address
encryption mode ciphers aes-ccm tkip
encryption vlan 2 mode ciphers aes-ccm tkip
encryption vlan 1 mode ciphers aes-ccm tkip
encryption vlan 3 mode ciphers aes-ccm tkip
ssid SSID_1
ssid SSID_2
ssid SSID_3
antenna gain 0
stbc
beamform ofdm
station-role root
interface Dot11Radio0.1
encapsulation dot1Q 1 native
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Dot11Radio0.2
encapsulation dot1Q 2
bridge-group 2
bridge-group 2 subscriber-loop-control
bridge-group 2 spanning-disabled
bridge-group 2 block-unknown-source
no bridge-group 2 source-learning
no bridge-group 2 unicast-flooding
interface Dot11Radio0.3
encapsulation dot1Q 3
bridge-group 3
bridge-group 3 subscriber-loop-control
bridge-group 3 spanning-disabled
bridge-group 3 block-unknown-source
no bridge-group 3 source-learning
no bridge-group 3 unicast-flooding
<snip>
interface GigabitEthernet0
no ip address
duplex auto
speed auto
interface GigabitEthernet0.1
bridge-group 1
interface GigabitEthernet0.2
bridge-group 2
interface GigabitEthernet0.3
bridge-group 3
interface BVI1
ip address 192.168.1.14 255.255.255.0
interface BVI2
ip address 192.168.2.2 255.255.255.0
no ip route-cache
interface BVI3
ip address 192.168.3.2 255.255.255.0
<snip>
Router config: --> image flash:c860vae-advsecurityk9-mz.151-4.M4.bin
<snip>
vlan 2
name VLAN_2
vlan 3
name VLAN_3
<snip>
switchport trunk allowed vlan 1-3,1002-1005
switchport mode trunk
no ip address
interface Vlan1
interface Vlan2
ip address 192.168.2.1 255.255.255.0
interface Vlan3
ip address 192.168.3.1 255.255.255.0
1 REPLY
Re: No ping possible between AIR-SAP1602I-E-K9 and Cisco 866VAE-
All,
classical "problem in front of the device" issue... .-((. For any reason in my opinion the AP was compareable to a L3 switch configured with SVI. In fact it seems to be compareable to an L2 switch where it is only possible to configure one SVI. Reading this
http://packetlife.net/blog/2012/feb/20/aironet-aps-bridge-groups-and-bvi/
solved my issue at the end of the day. So right now I have only one bvi configured with an ip address and this works.
992
