Not able to ping Cisco 2504 Mgmt IP / Urgent
Hi Team,
I am not able to ping Cisco WLC mgmt IP
Capture from WLC
(Cisco Controller) >show interface summary
Interface Name                   Port Vlan Id  IP Address      Type    Ap Mgr Gu
est
management                       1    663      10.210.126.133  Static  Yes    No
virtual                          N/A  N/A      1.1.1.1         Static  No     No
wifi-data                        1    662      10.210.126.3    Dynamic No     No
wifi-guest                       1    660      10.210.124.3    Dynamic No     No
Capture from Switch ( switch side is having trunk port)
switch3#sh run int gigabitEthernet 4/13
Building configuration...
Current configuration : 370 bytes
interface GigabitEthernet4/13
switchport trunk allowed vlan 660,662,663
switchport mode trunk
speed 100
duplex full
All the vlan having dhcp 660,662,663
Our L3 device is juniper NS 5200 firewall & From firewall I am not be able to ping the WLC IP
though I am learning the mac address in the firewall
fw3)-> get arp all | inc 10.210.126.
10.210.126.133  ece1a9548200   Wi-Fi-Vr/eth0/1.104    VLD    30      0       0     0 5FW2503(M)-> get arp all | inc 10.210.126.
Any quick help will be much appreciated as we have to go live
Br/Subhojit
Hall of Fame Super Silver
Re: Not able to ping Cisco 2504 Mgmt IP / Urgent
You have the correct gateway set on the management interface?
-Scott
VIP Purple
Noticed you have set speed 100 in switchport. WLC is expect to connect to Gigabit switch port & please remove that & try
Rasika
**** Pls rate all useful responses ****
Problem resolved.
thanks...
VIP Purple
what was the fix ?
Small query : How to change the AP side Lan port speed to 1 Gig/full duplex & Ap hostname ??
Over CLI / or Gui will be beneficial
VIP Purple
AP name
"config ap name "
Duplex & Speed
(WLC2) >config ap ethernet duplex ?
Configure Ethernet Port Duplex Auto/Half/Full
(WLC2) >config ap ethernet duplex full ?
speed          Configure Ethernet Port Speed Settings
(WLC2) >config ap ethernet duplex full speed ?
Configure Ethernet Port Speed Auto/10Mbps/100Mbps/1000Mbps
(WLC2) >config ap ethernet duplex full speed 1000 ?
all            Configures Ethernet Port Setting for all connected APs
     Enter the name of the Cisco AP.
Normally you should not change these and leave it auto/auto.
Rasika
Gold
Hi Subhojit,
AP name can be changed through GUI (once AP get registered to WLC) or through AP console. On AP console you can use below command
capwap ap hostname
AP speed and duplex can be changed through WLC CLI.
Below shows the commands for the same.
configure ap ethernet duplex speed
This command is supported with versions 4.1 and later only.
Hope that helps.
Najaf
Please rate when applicable or helpful !!!
It seems to be some issue of Access-list configuration or the gateway configuration.
Could you please check that?
299
