06-19-2010 07:20 AM - edited 07-03-2021 06:54 PM
I encounter one issue in AP. Not sure why the directory of nvram does not have any file and cannot write memory to the AP.
AP#wr
%No memory available
%No memory availablestartup-config file open failed (Not enough space)
AP#dir nvram:
Directory of nvram:/
%Error calling getdents for nvram:/ (Unknown error 89)
06-19-2010 05:59 PM
Errr ... It should be "dir flash:".
06-20-2010 03:34 PM
What does 'show startup' show?
/André
06-20-2010 05:57 PM
There is configuration in the startup. However, once i reload the AP the configuration will be lost.
Not sure why cannot save the configuration in the AP
06-20-2010 06:24 PM
What is the output to the command "dir flash:"?
06-21-2010 01:50 PM
The routers NVRAM might be faulty and if so you need an RMA and that is a issue that must be solved through TAC.
You can try the following first. Just press enter to confirm:
ROUTER#write erase
Erasing the nvram filesystem will remove all configuration files! Continue? [confirm]
[OK]
Erase of nvram: complete
ROUTER#write memory
Building configuration...
[OK]
ROUTER#
Above you see how the router should respond.
/André
