Number of wireless networks vs. signal strength
Dears,
Does the number of wireless networks (# of SSIDs) has anything to do w/ the sinal strength ?
I mean, we configured some new wireless networks (for mobiles and guests for example), and after that some users started to complain about poor sinal quality... packet losses... etc etc...
right now we have
SSID #1 - default Wlan for laptops
SSID #2 - mobiles and smartphones
SSID #3 - guest users
SSID #4 - consulting
SSID #5 - vip users (without shape)
SSID #6 - test network
thanks in advance!
VIP Purple
If you have more SSID, then definetely it will increase mgt overhead in the wireless media & affect wireless users throughput.
here is a good post give an idea how many SSIDs you should have while getting reasonable performance (overhead shoud be low within your WLAN). This is very important in 2.4GHz band only 3 CH available
http://www.revolutionwifi.net/2013/10/ssid-overhead-how-many-wi-fi-ssids-are.html
If users complain about signal strength, I would check the power level of each AP & see whether WLC is dynamically change the power of each AP.
Rasika
****Pls rate all useful responses ****
thanks for the quick reply!
where shall I go to config that ?
thnx again!
number of SSID is directly related to interference and hence signal issues.
Hall of Fame Super Gold
Re: Number of wireless networks vs. signal strength
The more SSIDs you have the more "chatty" the airwaves is going to become.  Up to four SSID is ideal.
I do not agree that you can have "interferrence" when you have many SSID.
Y'know something?  You can squeeze this much down to 4.
SSID 2, 3 & 4 can become one.
349
