OEAP600 Dual-Rlan w/7.2.203 code
                   The documentation says :
Only four clients can connect thru a remote LAN port on the 600 AP.
I have network oeap-600 dual-rlan-ports enabled.
Can I now have four clients on EACH remote LAN port?
I am feeding a 2960-8, 1 rlan feeding vl2 as management and the other rlan feeding vl3 as data.
I NEED 4 mac's on data.
The answer I think is 4 clients can connect thru remote LAN(s) total, just as we have 15 across all (controller) SSIDs of a single AP.
Darn, I was hoping for 4 each.  Just not enought table space to track anymore.
1 REPLY
AH, there ARE 4 each.  Provided you are not using a 2960 like I am.
When I use a pair of Linksys grade switchs, the switch's have no presents on Layer2.
Can one dumb down a 2960 a bit and loose the vl1 and port mac hits?
I don't really need management..
454
