08-13-2013 07:32 AM - edited 07-04-2021 12:38 AM
I am trying to get the office extend for one AP on remote location. But unfortunately I couldn't get it until now. On the controller I have allowed local switching under the two WLANs (QWHV and QWHVin51) and choose flexconnect and allow office extend under the AP. But until now the both WLAN doesn't show off on the remote location. It would be great if I get the information about the configuration on remote location switch configuration on which port the AP is connected. Because I believe that port has to configured as trunk and the native VLAN will be the local DHCP server. But until now the port is configured as access port. Because I am not sure which IP and network I should set on the switch for the both WLANs network on that remote switch. One thing to mention that I have also created a group for this office extend, choose those two WLANs and also choose the AP for it.
Here is the output config on the controller for that AP:
(Cisco Controller) >show ap config general xnwXXXX
Cisco AP Identifier.............................. 46
Cisco AP Name.................................... xnwXXXX
Country code..................................... DE - Germany
Regulatory Domain allowed by Country............. 802.11bg:-E 802.11a:-E
AP Country code.................................. DE - Germany
AP Regulatory Domain............................. 802.11bg:-E 802.11a:-E
Switch Port Number .............................. 1
MAC Address...................................... xx:xx:xx:xx:xx:xx
IP Address Configuration......................... DHCP
IP Address....................................... 10.151.253.195
IP NetMask....................................... 255.255.0.0
Gateway IP Addr.................................. 10.151.254.254
NAT External IP Address.......................... None
CAPWAP Path MTU.................................. 1485
Telnet State..................................... Enabled
Ssh State........................................ Enabled
Cisco AP Location................................ default location
Cisco AP Floor Label............................. 0
Cisco AP Group Name.............................. FlexGroup
Primary Cisco Switch Name........................ xnwYYYY
Primary Cisco Switch IP Address.................. 10.105.253.175
--More-- or (q)uit
Secondary Cisco Switch Name......................
Secondary Cisco Switch IP Address................ Not Configured
Tertiary Cisco Switch Name.......................
Tertiary Cisco Switch IP Address................. Not Configured
Administrative State ............................ ADMIN_ENABLED
Operation State ................................. REGISTERED
Mirroring Mode .................................. Disabled
AP Mode ......................................... FlexConnect in OfficeExtend mode
Public Safety ................................... Disabled
AP SubMode ...................................... Not Configured
Remote AP Debug ................................. Disabled
Logging trap severity level ..................... informational
Logging syslog facility ......................... kern
S/W Version .................................... 7.4.100.60
Boot Version ................................... 15.2.2.0
Mini IOS Version ................................ 7.4.1.37
Stats Reporting Period .......................... 180
Stats Collection Mode ........................... normal
LED State........................................ Enabled
PoE Pre-Standard Switch.......................... Disabled
PoE Power Injector MAC Addr...................... Disabled
Power Type/Mode.................................. Power injector / Normal mode
Number Of Slots.................................. 2
--More-- or (q)uit
AP Model......................................... AIR-CAP1602I-E-K9
AP Image......................................... C1600-K9W8-M
IOS Version...................................... 15.2(2)JB1$
Reset Button..................................... Enabled
AP Serial Number................................. XXXXXXXXX
AP Certificate Type.............................. Manufacture Installed
FlexConnect Vlan mode :.......................... Disabled
FlexConnect Group................................ Not a member of any group
Group VLAN ACL Mappings
FlexConnect Local-Split ACLs :
WLAN ID PROFILE NAME ACL TYPE
Flexconnect Central-Dhcp Values :
WLAN ID PROFILE NAME Central-Dhcp DNS Override Nat-Pat Type
1 QWHVin51 False False False Wlan
2 QWHV False False False Wlan
FlexConnect Backup Auth Radius Servers :
Primary Radius Server........................... Disabled
--More-- or (q)uit
Secondary Radius Server......................... Disabled
AP User Mode..................................... CUSTOMIZED
AP User Name..................................... admin
AP Dot1x User Mode............................... Not Configured
AP Dot1x User Name............................... Not Configured
Cisco AP system logging host..................... 255.255.255.255
AP Up Time....................................... 0 days, 00 h 11 m 19 s
AP LWAPP Up Time................................. 0 days, 00 h 10 m 07 s
Join Date and Time............................... Tue Aug 13 16:01:06 2013
Join Taken Time.................................. 0 days, 00 h 01 m 11 s
GPS Present...................................... NO
Ethernet Vlan Tag................................ Disabled
Ethernet Port Duplex............................. Auto
Ethernet Port Speed.............................. Auto
AP Link Latency.................................. Enabled
Current Delay................................... 8 ms
Maximum Delay................................... 16 ms
Minimum Delay................................... 16 ms
Last updated (based on AP Up Time).............. 0 days, 00 h 10 m 53 s
Rogue Detection.................................. Enabled
AP TCP MSS Adjust................................ Disabled
Hotspot Venue Group.............................. Unspecified
--More-- or (q)uit
Hotspot Venue Type............................... Unspecified
DNS server IP ............................. 10.151.251.2
DNS server IP ............................. 10.101.251.2
thanks in advance.
Pial
Solved! Go to Solution.
08-14-2013 04:43 AM
OfficeExtend is when you have an AP like a OEAP600 at a home office. You use FlexConnect when you have remote sites and each site has a wan connection back to your main site. So you need to enable FlexConnect, not Office Extend correct. They are two different things an I just want to be sure.
08-13-2013 07:55 PM
Are you doing OfficeExtend or FlexConnect?
08-14-2013 12:04 AM
Hello Scott,
thanks for your response. The truth I am quite new in this field and I want to have two officeextend wlan on a remote branch. So what I read from one blog that I have to enable flexconnect as well.correct me please if I am wrong. But what the missing point was about the switch/router configuration on which port the AP will connect. The DHCP IP address
10.151.253.195 the AP get from the local DHCP server and can connect to controller. I have added the attachments the configuration on wlc.
thanks for your co-operate.
08-14-2013 04:50 AM
If your really doing OfficeExtend, then you need to look at this guide as it goes over what stays local at the users home and what gets tunneled back to the WLC.
http://www.cisco.com/en/US/products/ps11579/products_tech_note09186a0080b7f10e.shtml
Scott
Help out other by using the rating system and marking answered questions as "Answered"
08-14-2013 04:39 AM
Hello Scott,
Today we have got any update from our customer that they can get the both WLAN which should be in office extend. Instead of gettting associated IP address from any of those WLAN network But they are getting wrong IP address (192.168.0.0/24). I add the screenshot from the client I have got.
08-14-2013 04:43 AM
08-14-2013 06:20 AM
Hello Scott,
thanks for your email. Ok it means we don't need officeextend in this scenario. But I would like to ask the questions regarding WLAN. I have disable the office extend. But I am still little confused about local and central switching. If I want the user at branch location will connect to one of the WLAN at controller, authencation will be done at controller and get the IP address from that WLAN range as well then do I need to enable central switching under WLAN configuration? Because remote branches don't have any internet connection and have to connect to the headquarter (where controller exist) over WAN etherconnect (done by the ISP). So it should be in the same IP range for the specific WLAN to get access central server access as well as for internet. Presently under WLAN local switching is enabled. Do I have to configure another DHCP range for the WLAN on remote branch and If I do whether I should configure the switch port as trunk and configure the native vlan for AP to get IP from local DHCP server?
08-15-2013 02:29 AM
Hello Scott,
I didn't get any feedback. I hope the problem I have been facing for flexconnect should be fixed soon. When the client try to login on a specific WLAN on controller we see the client MAC address but it cannot get any IP address. So the client status shows as disassociated. For that specific wlan we have created on the branch office another dhcp range on dhcp server and create a trunk port to allow that VLAN.
trunk 1,59
AP----------------->Switch-------------->ASA FW------------------->ISP layer 2--------------->ASA FW--------------->Controller
Native 1 | Ethernetconnect WLAN 59
Local DHCP
Server for VLAN1
and VLAN59
I would be glad to get an advice.
thanks
Pial
