Only 1 SSID broadcasting using mbssid?
Hello
I was looking for some assistance. The configuration I am looking to achieve is to have 2 SSIDs broadcasting, which should be straightforward. However, only one of them is broadcasting. The current AP configuration is below, can someone advise what I am missing?
WIFI-PUB is the one that is broadcasting, Florida is the SSID not broadcasting
Thanks in advance
ap#sh run
Building configuration...
Current configuration : 2526 bytes
version 12.4
no service pad
hostname ap
logging rate-limit console 9
enable secret 5 $1$//Xt$Tq8A/NMjUar6teWO3jQxG1
no aaa new-model
dot11 mbssid
dot11 syslog
dot11 vlan-name vlan2 vlan 2
dot11 vlan-name vlan3 vlan 3
dot11 ssid Florida
   vlan 3
   authentication open
   authentication key-management wpa
   mbssid guest-mode
   wpa-psk ascii 0 password1
dot11 ssid WIFI-PUB
   vlan 2
   authentication open
   mbssid guest-mode
   wpa-psk ascii 0 password2
username admin privilege 15 secret 5 $1$/XQx$m9zYPwEOXNgBFXs3yR4NK/
bridge irb
interface Dot11Radio0
 no ip address
 no ip route-cache
 encryption mode ciphers tkip
 encryption vlan 2 mode ciphers tkip
 encryption vlan 3 mode ciphers tkip
 ssid Florida
 ssid WIFI-PUB
 antenna gain 0
 speed  basic-1.0 2.0 5.5 11.0 6.0 9.0 12.0 18.0 24.0 36.0 48.0 54.0 m0. m1. m2. m3. m4. m8. m9. m10. m11. m12. m13. m14. m15.
 channel 2462
 station-role root
interface Dot11Radio0.1
 encapsulation dot1Q 1 native
 no ip route-cache
 bridge-group 1
 bridge-group 1 subscriber-loop-control
 bridge-group 1 block-unknown-source
 no bridge-group 1 source-learning
 no bridge-group 1 unicast-flooding
 bridge-group 1 spanning-disabled
interface Dot11Radio0.2
 encapsulation dot1Q 2
 no ip route-cache
 bridge-group 2
 bridge-group 2 subscriber-loop-control
 bridge-group 2 block-unknown-source
 no bridge-group 2 source-learning
 no bridge-group 2 unicast-flooding
 bridge-group 2 spanning-disabled
interface GigabitEthernet0
 description the embedded AP Gigabit Ethernet 0 is an internal interface connection AP with the host router
 no ip address
 no ip route-cache
interface GigabitEthernet0.1
 no ip route-cache
 bridge-group 1
interface GigabitEthernet0.2
 no ip route-cache
 bridge-group 2
interface BVI1
 ip address 10.0.0.2 255.255.0.0
 no ip route-cache
no ip http server
no ip http secure-server
bridge 1 protocol ieee
bridge 1 route ip
bridge 2 protocol ieee
line con 0
 privilege level 15
 login local
 no activation-character
line vty 0 4
 login local
cns dhcp
end
1 ACCEPTED SOLUTION
VIP Purple
Hi,No that must show but
No that must show but before that you have to create a subinterface from dot11radio0.3 and gig0.3
add this config:
interface GigabitEthernet0.3
 encapsulation dot1Q 3
 bridge-group 3
interface Dot11Radio0.3
 bridge-group 3
Dont forget to rate helpful posts
VIP Purple
HI Richard,ADD this command
HI Richard,
ADD this command hunder interface dot11radio0:
AP#Conf t
AP(config-if)#interface Dot11Radio0
AP(config-if)#mbssid
http://rscciew.wordpress.com/2014/05/24/multiple-ssid-configurations-on-autonomous-ap/
Thats all you need to broadcast both ssid.
Hi Sandeep Thanks for your
Hi Sandeep
Thanks for your prompt reply, I have entered that, the router accepts it, but when I run a sh run, it does not appear under the do11radio0 int, is there something conflicting?
ap#config t
Enter configuration commands, one per line.  End with CNTL/Z.
ap(config)#int dot11radio0
ap(config-if)#mbssid
ap(config-if)#exit
ap(config)#exit
ap#copy run start
Destination filename [startup-config]?
[OK]
ap#sh run
 no ip address
 no ip route-cache
 ssid Florida
 ssid WIFI-PUB
 antenna gain 0
 channel 2462
 station-role root
Hi, try removing the
try removing the following command:
int d0
no encryption mode ciphers tkip
Thanks and regards,
Manas Pratap Singh
VIP Purple
add this config:
 bridge-group 3
 bridge-group 3
Hi Sandeep Just to let you
Hi Sandeep
Just to let you know its working now, although it still doesn't show mbssid in the dot11radio0 interface, it does if I put in no mbssid, so perhaps it doesn't show if there are multiple ssids on the int anyway.
Thanks for your help
182
