Community Member
OS X clients being denied on Cisco WiFi
We had to setup our wifi controller again and we had no problems before until it was setup this 2nd time.  iPhones, Androids, Windows computers all work fine, but OS X will not connect.  Turning on debugging on the Cisco controller and then trying to connect doesn't even log anything.  Tried OS 10.8.5 and 10.9.2 and same issue.  You can see the airport flashing the bars trying to connect and then nothing.
On the 10.8.5 client its asking for Enterprise Credentials and we don't even have  802.1x on anywhere.  Tried 3 different Macs, two iMacs and a Macbook.
APs: AIR-CAP3602E-A-K9
Cisco IOS Version: 7.4.121.0
show wlan 2
WLAN Identifier.................................. 2
Profile Name..................................... wifiit
Network Name (SSID).............................. wifiit
Status........................................... Enabled
MAC Filtering.................................... Disabled
Broadcast SSID................................... Disabled
AAA Policy Override.............................. Disabled
Network Admission Control
  Client Profiling Status ....................... Disabled
   DHCP ......................................... Disabled
   HTTP ......................................... Disabled
  Radius-NAC State............................... Disabled
  SNMP-NAC State................................. Disabled
  Quarantine VLAN................................ 0
Maximum number of Associated Clients............. 0
Maximum number of Clients per AP Radio........... 200
Number of Active Clients......................... 3
Exclusionlist Timeout............................ 60 seconds
Session Timeout.................................. 86400 seconds
User Idle Timeout................................ 14400 seconds
User Idle Threshold.............................. 0 Bytes
NAS-identifier………………………….. vWLC
CHD per WLAN..................................... Enabled
Webauth DHCP exclusion........................... Disabled
Interface………………………………… vlan2
Multicast Interface.............................. Not Configured
WLAN IPv4 ACL.................................... unconfigured
WLAN IPv6 ACL.................................... unconfigured
mDNS Status...................................... Disabled
mDNS Profile Name................................ unconfigured
DHCP Server...................................... Default
DHCP Address Assignment Required................. Disabled
Static IP client tunneling....................... Disabled
Quality of Service............................... Silver
Per-SSID Rate Limits............................. Upstream    Downstream
Average Data Rate................................   0          0
Average Realtime Data Rate.......................   0          0
Burst Data Rate..................................   0          0
Burst Realtime Data Rate.........................   0          0
Per-Client Rate Limits........................... Upstream    Downstream
Scan Defer Priority.............................. 4,5,6
Scan Defer Time.................................. 100 milliseconds
WMM.............................................. Allowed
WMM UAPSD Compliant Client Support............... Disabled
Media Stream Multicast-direct.................... Disabled
CCX - AironetIe Support.......................... Disabled
CCX - Gratuitous ProbeResponse (GPR)............. Disabled
CCX - Diagnostics Channel Capability............. Disabled
Dot11-Phone Mode (7920).......................... Disabled
Wired Protocol................................... None
Passive Client Feature........................... Disabled
Peer-to-Peer Blocking Action..................... Disabled
Radio Policy..................................... All
DTIM period for 802.11a radio.................... 1
DTIM period for 802.11b radio.................... 1
Radius Servers
   Authentication................................ Disabled
   Accounting.................................... Disabled
   Dynamic Interface............................. Disabled
   Dynamic Interface Priority.................... wlan
Local EAP Authentication......................... Disabled
802.11 Authentication:........................ Open System
   FT Support.................................... Enabled
   Static WEP Keys............................... Disabled
   802.1X........................................ Disabled
   Wi-Fi Protected Access (WPA/WPA2)............. Enabled
      WPA (SSN IE)............................... Disabled
      WPA2 (RSN IE).............................. Enabled
         TKIP Cipher............................. Disabled
         AES Cipher.............................. Enabled
                                                               Auth Key Management
         802.1x.................................. Disabled
         PSK..................................... Enabled
         CCKM.................................... Disabled
         FT-1X(802.11r).......................... Disabled
         FT-PSK(802.11r)......................... Enabled
         PMF-1X(802.11w)......................... Disabled
         PMF-PSK(802.11w)........................ Disabled
      FT Reassociation Timeout................... 20
      FT Over-The-DS mode........................ Enabled
      GTK Randomization.......................... Disabled
      SKC Cache Support.......................... Disabled
      CCKM TSF Tolerance......................... 1000
WAPI.......................................... Disabled
   Wi-Fi Direct policy configured................ Disabled
   EAP-Passthrough............................... Disabled
   CKIP ......................................... Disabled
   Web Based Authentication...................... Disabled
   Web-Passthrough............................... Disabled
   Conditional Web Redirect...................... Disabled
   Splash-Page Web Redirect...................... Disabled
   Auto Anchor................................... Disabled
   FlexConnect Local Switching................... Enabled
   flexconnect Central Dhcp Flag................. Disabled
   flexconnect nat-pat Flag...................... Disabled
   flexconnect Dns Override Flag................. Disabled
   FlexConnect Vlan based Central Switching ..... Disabled
   FlexConnect Local Authentication.............. Disabled
   FlexConnect Learn IP Address.................. Enabled
   Client MFP.................................... Optional
   PMF........................................... Disabled
   PMF Association Comeback Time................. 1
   PMF SA Query RetryTimeout..................... 200
   Tkip MIC Countermeasure Hold-down Timer....... 60
AVC Visibilty.................................... Disabled
AVC Profile Name................................. None
Flow Monitor Name................................ None
Call Snooping.................................... Disabled
Roamed Call Re-Anchor Policy..................... Disabled
SIP CAC Fail Send-486-Busy Policy................ Enabled
SIP CAC Fail Send Dis-Association Policy......... Disabled
KTS based CAC Policy............................. Disabled
Assisted Roaming Prediction Optimization......... Enabled
802.11k Neighbor List............................ Enabled
802.11k Neighbor List Dual Band.................. Disabled
Band Select...................................... Disabled
Load Balancing................................... Disabled
Multicast Buffer................................. Disabled
 Mobility Anchor List
 WLAN ID     IP Address            Status
802.11u........................................ Disabled
MSAP Services.................................. Disabled
We are using WPA+WPA2 with WPA 2 Policy checked and AES checked along with "PSK" and "FT PSK" checked with our PSK set as ASCII.  Everything looks correct.  Anyone know what setting would not let OS X not even try and connect with our Wifi network?  Is it ok to have "PSK" and "FT PSK" enabled on same WLAN?
Thank you in advance!!
1 ACCEPTED SOLUTION
VIP Purple
No, I am not sure, I thought
No, I am not sure, I thought you would able to test & see.
When you tick that check box you are enabling 802.11r, & if client is not supporting that, then client won't be able to join. Below is from the 7.4 config guide under guidelines & limitation section.
Legacy clients cannot associate with a WLAN that has 802.11r enabled if the driver of the supplicant that is responsible for parsing the Robust Security Network Information Exchange (RSN IE) is old and not aware of the additional AKM suites in the IE. Due to this limitation, clients cannot send association requests to WLANs. These clients, however, can still associate with non-802.11r WLANs. Clients that are 802.11r capable can associate as 802.11i clients on WLANs that have both 802.11i and 802.11r Authentication Key Management Suites enabled.
1. The workaround is to enable or upgrade the driver of the legacy clients to work with the new 802.11r AKMs, after which the legacy clients can successfully associate with 802.11r enabled WLANs.
2. Another workaround is to have two SSIDs with the same name but with different security settings (FT and non-FT).
Rasika
**** Pls rate all useful responses ****
VIP Purple
Hi,Did you test without FT
Did you test without FT PSK ? Give it a try & see
Rasika
Community Member
No because I'm not allowed to
No because I'm not allowed to change anything, have to make a case first. Fun Fun!  Is it a known problem to have FT PSK with OS X that you know of?
VIP Purple
Rasika
Community Member
Well you sorta answered my
Well you sorta answered my next question, step 2 is what I want to do!  Thanks!
Community Member
Ok turning off FT-PSK did
Ok turning off FT-PSK did make things work!
Having FT-PSK on and OS X not working is that more of a hardware radio issue not supporting it or is it the Software/Drivers in OS X not supporting FT-PSK??
Doing another WLAN with the same SSID - Is that a supported method to do?  How does a client that works with FT-PSK know which one to pick, will it always pick the WLAN that has FT-PSK on?
VIP Purple
Hi Glad to see you get it
Glad to see you get it working by disabling 802.11r.
"Having FT-PSK on and OS X not working is that more of a hardware radio issue not supporting it or is it the Software/Drivers in OS X not supporting FT-PSK??"
This is because MAC OS does not support 802.11r, When Apple release an update to support this it will work like anyother iOS devices. Here is a link to 802.11r supported iOS devices.
http://support.apple.com/kb/HT5535
"Doing another WLAN with the same SSID - Is that a supported method to do?  How does a client that works with FT-PSK know which one to pick, will it always pick the WLAN that has FT-PSK on?"
Yes this is a workaround, if you want to enable 802.11r where you have mixed mode clients where some does supports 802.11r & some doesn't.
I am not sure, if you have two SSIDs (with FT & without FT support) & Client is supporting 802.11r, which one client prefer to connect. Here is a good article about 802.11r with some useful packet captures as well
http://wireless-richard.blogspot.com.au/2012/09/sniffer-of-80211r-roaming.html
Rasika
Community Member
Thanks for the help and quick
Thanks for the help and quick responses!  Greatly appreciated!
TAC has been open with Cisco and Bug report to Apple.  Hopefully Apple fixes this soon.  Easy workaround, but Apple should be supporting Industry standards, especially ones from 2008 that are viable today and when Windows and other OS's and devices do.
1913
