Other: SSID and Auth_not_A
Any one has any experience with this behavior:
If I reboot the client it will connect for a few seconds but then it will lose its IP and go to this state.  "show dot11 association" will show it under Other SSID.  And it just won't connect back.
Address           : 0023.68b2.14f6     Name             : NONE
IP Address        : 0.0.0.0            Interface        : Dot11Radio 0
Device            : unknown            Software Version : NONE
CCX Version       : NONE               Client MFP       : Off
State             : Auth_not_A          Parent           : self
SSID              :
VLAN              : 0
Hops to Infra     : 1
Clients Associated: 0                  Repeaters associated: 0
The Auth_not_A is a state
The Auth_not_A is a state where the client start the authentication process, but never
follow up with association. This can happen if you have some bad coverage.
Time for site survey.
Unfortunately, it doesn't gives a very good idea and clear explanation, due to which a documentation bug was filed to have these clearly defined :
CSCef63194    need to document the state in show dot11 association
-Thanks
Vinod
-Thanks Vinod **Rating Encourages contributors, and its really free. **
This client is like few feet
This client is like few feet away from this particular AP.
Than you probably want to run
Than you probably want to run the debug to see why the client is not able to join. Check debug document here.
-Thanks
Vinod
check for signal strength
check for signal strength ,interference , site survey.
350
