Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
Please help with Wireless AP-1242AG-E-K9
Hello community,
I have troubles with configuring subj Wireless device, so I can connect to the Wireless but IP adress didnt assigned to client device dispite of DHCP pool configured. As you may see this AP connected by etehernet to anther SOHO router with Static IP on BVI1.
version 12.4
no service pad
service password-encryption
hostname N_WIFI_3
logging buffered 20000 warnings
logging rate-limit console 9
enable secret 5 pass
no aaa new-model
no ip domain lookup
ip domain name 192.168.0.1
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.3.1
ip dhcp pool N_WIFI_3
   network 192.168.3.0 255.255.255.0
   default-router 192.168.3.1
   lease 10
dot11 ssid N_WIFI_3
   authentication open
   authentication key-management wpa
   guest-mode
   wpa-psk ascii 7 025756085F53597614
power inline negotiation prestandard source
username Cisco password 7 096F471A1A0A
bridge irb
interface Dot11Radio0
ip address pool N_WIFI_3
no ip route-cache
encryption mode ciphers aes-ccm
ssid N_WIFI_3
no ip route-cache
ssid N_WIFI_3
speed  basic-1.0 2.0 5.5 11.0 6.0 9.0 12.0 18.0 24.0 36.0 48.0 54.0
station-role root bridge
bridge-group 1
bridge-group 1 spanning-disabled
interface Dot11Radio1
no ip address
no ip route-cache
shutdown
no dfs band block
channel dfs
station-role root
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface FastEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
bridge-group 1
interface BVI1
description Local
ip address 192.168.0.3 255.255.255.0
no ip route-cache
ip default-gateway 192.168.0.1
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
bridge 1 route ip
line con 0
line vty 0 4
login local
End
1 ACCEPTED SOLUTION
VIP Purple
Re: Please help with Wireless AP-1242AG-E-K9
You have configured wrong command ( station role root bridge) under Radio 0 interface.Due to this wireless client cannot associate to it & normally that mode is used when you configurre ROOT - NON-ROOT bridge set up.
Here is the very basic configuration you required this to get working. (Hihglighted purple color missing info). Also configure this on Radio1 as well to give better experience for the client who is  support on 5GHz
hostname N_WIFI_3
   lease 10
dot11 ssid N_WIFI_3
   authentication open
   authentication key-management wpa version 2
   guest-mode
ssid N_WIFI_3
speed default
station-role root
bridge-group 1
ssid N_WIFI_3
no shutdown
station-role root
bridge-group 1
bridge-group 1
interface BVI1
See this post as well
https://supportforums.cisco.com/thread/2243196
Rasika
*** Pls rate all useful responses ***
Hall of Fame Super Silver
Here are some links you can review.  The dhcp you set will not work since you have to define bridge groups for different vlans.
Here are some docs for configuraing multiple ssids or vlans and dhcp sever
https://supportforums.cisco.com/docs/DOC-14496
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_configuration_example09186a0080c0b93c.shtml
http://www.my80211.com/cisco-auton-cli-commands/2010/3/8/autonomous-configure-a-cisco-ap-to-provide-dhcp-services.html
Scott
Help out other by using the rating system and marking answered questions as "Answered"
-Scott
VIP Purple
hostname N_WIFI_3
   lease 10
dot11 ssid N_WIFI_3
   authentication open
   guest-mode
ssid N_WIFI_3
speed default
station-role root
bridge-group 1
ssid N_WIFI_3
no shutdown
station-role root
bridge-group 1
bridge-group 1
interface BVI1
Rasika
Thank you very much. All works fine
289
