POE issues with none Cisco switches
Running IOS version 12.3(7)JA1 on AP1200 b/g, after turning off CDP on AP. AP failed to initiate power from the none Cisco POE switch. Please advice.
Re: POE issues with none Cisco switches
does it work when CDP is turned on?
Martin
Hi Martin,
No it doesn't work. The reason is the non-cisco device switch doesn't support CDP. It does support IEEE and 802.3af.
Murtada
Murtada,
The Cisco 1200 AP is not 802.3af compliant and will not work with a pure 802.3af switches. You should be able to add a PDPS800 which will receive power from an 802.3af switch and output 48VDC plus data to the 1200.The PDPS800 will need to be located near the 1200 AP. See URL below
http://www.cisco.com/en/US/products/hw/wireless/ps430/prod_technical_reference09186a008039e541.html
Morty
173
