PAR
Community Member
Point to Multipoint with 2 root bridges
Hello
We are looking at a point to multipoint solution for providing data connectivity to cranes in a large warehouse. The cranes operate on static rails so they can only move in a set pattern.
The plan is to install a root bridge at 1 end of the warehouse with a directional antenna providing wireless for the cranes. Each crane will have a non-root bridge installed on the outside and an RJ-45 cable linking to the device on the inside.
To provide additional network coverage at the opposite end of the warehouse is it possible to install a second root bridge. If so would the cranes automatically associate with either root bridge as they move along the crane track?
Hope this makes sense and thanks in advance for any guidance.
Paul
1 ACCEPTED SOLUTION
VIP Purple
Hi Paul,What you require is
Hi Paul,
What you require is configure the crane AP as Work Group Bridge (not a non-root bridge). In that way that AP acting as a normal client to any other AP (it can associate to a root AP in autonomous mode or any other Light weight AP managed by WLC as well). So you will get proper roaming when crane is moving.
Read below posts & that should give you enough guidance to do this.
1. http://mrncciew.com/2013/06/13/wgb-with-psk/
2. http://mrncciew.com/2013/06/16/ios-ap-wgb-with-multiple-vlan/
3. http://mrncciew.com/2013/04/30/wgb-with-capwap/
4. http://mrncciew.com/2013/07/24/wgb-roaming-part-1/
Pls do not forget to rate our responses if you find it useful.
Rasika
VIP Purple
Hi Paul,
Rasika
PAR
Community Member
Hi Rasika,Thanks for the
Hi Rasika,
Thanks for the quick and informative response, much appreciated.
Due to the harsh environment the cranes work in we were thinking of installing the 1530 AP with an external directly antenna at each end of the warehouse and at the crane end use the 1530 with internal antenna.
Can you see any issues with using this product or would you consider another AP?
thanks again
Paul
VIP Purple
 No that AP model should be
No that AP model should be fine
Rasika
Bronze
Hello, Paul. Check the
Hello, Paul.
Check the following Outdoor Aironet models to determine if the 1530 would be the best model for your wireless requirement:
http://www.cisco.com/c/en/us/products/wireless/buyers-guide.html#~outdoor
Let me know if you have additional concerns or e-mail (adawa@cisco.com) me directly. Kind regards.
PAR
Community Member
Thanks Adawa,Looking at the
Thanks Adawa,
Looking at the comparison I believe the 1530 will do nicely, unless you have some concerns.
Do you have a table detailing the minimum supported WLC software version for the APs.
Paul.
VIP Purple
Hi Paul,Here is the WLC
Hi Paul,
Here is the WLC software compatibility matrix
http://www.cisco.com/c/en/us/td/docs/wireless/compatibility/matrix/compatibility-matrix.html
Table 2 listed min WLC software required for each AP model. In case of 1530 series you require 7.6.100.0 or above if it is managed via a WLC.
Rasika
**** Pls rate all useful responses ****
88
